Question about Remington Electric Chain Saw
My chain on the remington elec saw will not spin
  • 4 Answers
Assuming that you do not have something jamming the mechanism (twigs etc.), your chain has been disabled and needs to be replaced. To do this your best bet is probably to look on Ebay or one of the other auction sites. As you probably know the reference above no longer is carrying Remington 6 inch chains.
Posted on Aug 25, 2010
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
What kind of oil is used for a 12'' 115v elec chainsaw model lnt-2
Hi, any brand of bar and chain oil is fine. Hope this helps, regards Phil.
Jun 14, 2011 | Remington Electric Chain Saw
I have a Remington 16"
most any bar and chain oil for chain saws will work. The cheaper the better just make sure you keep the chain oiled up. if you can touch the chain and oil oil does'nt get on you you not using enoght and put oil right on the chain. certainly when you put the saw away to store it. even wrapping the bar and chain in a rag with oil in it is a good idea as it'll be ready for next time.
Jan 31, 2011 | Remington 16" Electric Chain Saw Assembled...
I was given a Remington 2.5 HP Elec Saw without the owner's manual. What type of oil is needed ? ?
This is one of the better OMs (model M30016AS) available for a Remington (they are no longer in production, parts are becoming hard to find):
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Sep 08, 2010 | Remington Garden
Remington 10" elec pole saw diagram needed
Your IPB follows (we are prohibited from contacting you directly):
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
All Remington OMs and IPBs:
Remington.com
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Be gentle with it, they are no longer in production, some parts cannot be found.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 21, 2010 | Remington Polesaw Wizard
Motor turns --sprocket or chain doesn't
I'm assuming your kill switch is not engaged, the front handle should be pulled to the rear. It's normal to have some damage on the sprocket from loose chains catching on the corner so I doubt you need a new one. The motor turns? I'm assuming you're talking about the clutch, and if the clutch spins but the chain does not it sounds like your bar may be damaged or as you said the sprocket may need to be replaced if it's seriously been misused.
Apr 15, 2010 | Remington 16" Electric Chain Saw
Does my remington chain saw model #m15014AS go with the remington ext.pole model #rps96
No, the largest electric pole chain saw that can be attached to a pole with the Remington Pole Saw kit, is a 10" saw.
You can go to Master Distributors to find out more detailed info about your situation and speak with one of their reps.
http://www.remingtonchainsaw.com/
Hope you found this very helpful, best regards!
Aug 07, 2009 | Remington Electric Chain Saw
Unable to tighten chain .. too droopy.
There are usually two 7/16" nuts on the side of the chain saw. Loosen those a little first, then turn the screw to tighten the chain - not too tight or you'll stretch out the chain when you use it. Don't forget to re-tighten the two nuts before using the chainsaw.
May 16, 2009 | Remington Electric Chain Saw
Replancement bar for 16 inch remington chain saw
The bar is the piece of metal that the chain goes around. This link has lots of info on your saw http://www.remingtonchainsaw.com/chainsaw.html
Mar 31, 2009 | Remington Electric Chain Saw
Remington Electric Chain Saw  Logo
163 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
