Question about Pioneer AVH-P5700DVD Car DVD Player
Can u cut the cord on the bottom right on the back
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 2,226 Answers
Why would you want to do that???????????
Posted on Dec 09, 2009
SOURCE:
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
I aquired a used Wii. When I hooked it up it worked great. Now, all of a sudden, the top and bottom of the screen are cut off. I did not change any settings on the console or TV and can't figure out how...
You might want to try and gently clean the video plugin on the back of the Wii and the cord. It could be a dirty connection not allowing the entire video signal to come through. if not, try a different cord
Aug 11, 2013 | Nintendo Wii Console
My son cut the power cord to the tv, how do I replace the cord? can I replace the whole cord from the back of the TV?
That cord in this model is usually a plug in--inside the set it either goes to a plug or is soldered in place.
Depending on how short it was cut it can be repaired--notice that here the cord has two sides---one will be smooth and the other has a white stripe or is rough----if spliced the splices must match the ones on what is left of the cord-----cord is polarized and should not be plugged in unless matched to set.
A fairly easy repair if done right--most people or any outside repair person can easily do this.
May 04, 2012 | Philips 60PP9202 60" Rear Projection...
Bose quietcomfort15 headphones
Riley, it could be that the membrane on the cone of the speaker is damaged, if that were the case, then you will have to replace the headset with a new one; also check the wiring to the speaker there may be a bad connection to the speaker, if that is the problem, it can be solved by soldering the connection back to the the speaker. you can also squeeze the cord starting from the bottom and slide your fingers up the cord, listen through the headphones for any break inn signal, if that happens,cut the wire and re-splice the wire and tape the wiring with electrical tape. good luck.
Apr 30, 2012 | Bose QuietComfort 15 Headphones
Replace starter cord
Undo the screws holding the housing of the starter cord & remove the whole thing.
Before continuing it may be wise to take a picture of the pulley & how its held on so you can put it together correctly.
Inside you should see a removable clip attached to a moving nylon peg thing, remove this, then a washer, then remove the round plastic pulley that holds the cord.
Remove the old cord.
Thread one end of the new cord (ensure it's the same thickness) from the outside of the pulley through the hole so it comes out in the middle as it was before.
Tie a knot in it, trim off any eccess cord & pull it back through, tucking the knot neatly into the place where the knot goes.
Wrap the cord 3 or 4 times round the pulley & thread the loose end through the hole in the housing.
Put the pulley back in the housing as it came off & replace the washer, peg & clip.
Pull the cord to make sure it springs back ok.
***Now pull the chord right out & slowly let the spring pull it back in. Now thread your pull handle on right up to the housing, put a knot in it a bit further than this point so the spring holds the handle tight to the housing and its not dangling loose.DONT CUT THE ECCESS OFF YET
Ensure youre happy with the length of cord when its pulled out
If its too short, undo the knot, leave the pulley in place, use a thin screwdriver to pull the cord into the housing to wrap it round the pulley one more time (theres normally a notch cut out of the pulley to get the cord round between the pulley & housing)
Now repeat from ***
Now screw the housing back in place.
It's easier to do than write!!!!
Sep 13, 2011 | Garden
E series was working came unpluged while running, pulgged it back in and now it wont come on. Why?
This could be several things. Any time a vacuum cleaner doesn't start, it can either be caused by a bad cord, the plug on the end of the cord, the switch, or the motor on the vacuum.
Judging by what you said in your repair question that you were using the vacuum and it was working fine, and only when the vacuum came unplugged it stopped working. This definitely sounds like your plug probably went bad. When the vacuum is plugged into the wall, and the cord is pulled tight, this can caused too much tension to be placed on the actual plug that's in the wall. We see this quite frequently, especially from people that pull on the vacuum cord from across the room to unplug it. When the plug has too much stress on it, it will cause the prongs to either bend, or loose their connection on the inside of the plug, preventing the vacuum from getting electricity.
An easy way to test the plug without tearing down the entire vacuum is to just wiggle the prongs at the end of the cord. Are the prongs loose at all? If the prongs are loose, this is a sure sign that your plug has gone bad. If the prongs are tight, then it still may be the plug itself, or possibly the entire cord assembly. Again, because you stated the vacuum was working fine until it became unplugged, I tend to think that the plug is probably bad.
Since the plug is the easiest thing to fix, I would recommend trying to replace the plug first. If this doesn't fix it, it can only be the whole cord assembly (which you'll have a new plug anyways), the switch, or the motor.
This is step by step instructions on how to replace the plug on a vacuum. This was a repair that I helped with on a vacuum that had a three wire cord, but putting a two wire plug on will be the same repair minus the ground wire. Honestly, I use a three wire plug with all of the plugs that I repair, regardless of whether or not the vacuum has two or three wires. Typically the three wire plugs are better quality, and hold the wires better. It won't hurt the vacuum or your outlet if you don't have a wire connected to the third prong. You can pick up an electrical plug at any hardware store, or Home Depot.
Here's how to change the plug:
Step 1. Make sure the vacuum is unplugged. Then cut the existing plug off of your Rainbow, at the very end of the cord, right before the plug molding starts:
Step 2. There are typically three screws that hold the plug part into the base of the plug assembly, remove these screws to separate the two parts of the plug:
Step 3. Slide the cord of your rainbow through the bottom part of the plug so the cord sits about 5-6 inches past the opening of the bottom part of the plug:
Step 4. Carefully cut the outer cord jacket off, about one inch from the end of the cord with a sharp knife. Make sure that you don't cut into the actual wires below, and that you're only cutting the outer part of the cord. If you accidentally cut into the wires, just cut the cord again and start over. This is how you can remove the cord jacket:
Step 5. After removing the cord jacket from the cord, cut the paper filling material off, so you have just the two wires (make sure that there is no copper showing through the wires) are the only thing sticking out. Make sure that you have cut enough cord jacket so the wires have enough room to fit into their respective terminals:
Step 6. Use a pair of wire strippers to strip the insulation off of the wires. Strip the wire insulation about about 1/2 inch down both wires.
Step 7. It's best if you twist the copper wires to keep them from fraying.
Step 8. When using a heavier duty plug like the 3 wire plug shown in this repair, the wire actually uses a clamping device to hold down the wire. Cheaper 2 wire plugs just wrap the wire around a screw, in my opinion the heavier duty three wire cords are much safer, and better:
Step 9. Put the White wire into the clamp that has the silver screw, and the black wire into the clamp with the gold screw, and tighten down the screws that hold the wires into place:
Step 10. Tug firmly on both wires to make sure both are securely fastened inside the terminals. If a wire comes loose, loosen the terminal, put the wire back inside, and then tighten down securely.
Step 11. Usually the 3 screws that secure the top of the plug to the bottom part, are aligned with two screws on the top, and one screw on the bottom. Try and line up the screws with the female receptacles on the bottom part of the plug. There may also be a notch on one (and only one) of the terminals, and similar notch on the bottom part of the plug to help you align the two parts correctly:
Step 12. After aligning the screws on the top part of the plug to the bottom part, tighten each screw until snug, then go back and tighten down completely only after each screw is snug. Screw all three screws until they no longer turn:
Step 13. The last step is tighten the lower part of the plug assembly down on top of the cord. This helps relieve stress on the end of the wire that is connected to the plug prongs, just in case the cord is pulled on, this will prevent the cord from pulling out of the top part of the plug assembly. Make sure that you tighten both screws on the lower portion of the plug as tight as absolutely possible:
And you're done! This is how the completed plug should look when you're finished:
Now just plug the vacuum cleaner into a wall outlet, and see if the vacuum turns on. Hopefully it does, and this fixed your problem. If it didn't, then this means that it can only be the cord itself, the switch (in 10 years I've never replaced a Rainbow E or E2 switch), or the motor. I'm fairly confident from what you explained in your repair question that this will fix your problem. If it doesn't however, please just use the Clarification Request form here on Fixya, and just leave a comment explaining that it didn't fix the problem. I will then follow up on how you can test the motor, the cord, and the switch on your Rainbow.
I hope this actually fixed it however. If this was helpful to you in figuring out what happened to your Rainbow, please be kind and rate my repair as helpful by clicking the thumbs up icons on the repair page. This little gesture really and truly does keep me coming back to Fixya and helping people solve their vacuum problems. I really do appreciate it, and I look forward to helping you further diagnosis your Rainbow should you need it.
Thanks again,
Chris J.
GoVacuum
Apr 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Someone cut off cord.Iwant to wire on new cord in proper place
If you remove the bottom panel of the dishwasher below the door right at the floor you will see on the right hand side, a metal box with a philips head screw holding the side of the box dowm. If you remove this screw you will see the electrical connections that you can wire this pig tail to properly
Good luck hope this helped you some
Dave
Feb 19, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Can't hear sound on one of the headphone's speaker
It's less common for one of the speakers to go bad in a set of headphones. It's possible - but there are more common problems that will cause this. I assume you have tried the headphones on another device to rule our a problem with the device you are currently listening with and using the other device, you still only hear audio from the left speaker.
The wires in the cord that connect the plug to the headphones are very thin and are susceptible to breaking. The most commmon place for these wires to break is at the point where the cord is flexed or stressed the most. Those points are:
1. Right at the plug
2. Where the wire enters into the left and right speaker.
There are occasions where I have seen the wires become unsoldered from the speaker terminals within the headphones themself.
What You Can Do:
1. While listening with the headphones, try flexing the cord back & forth at the plug and where the wire goes into the right speaker. See if the audio will come back and cut out again.
2. What I have done is cut the cord about 3" back from the plug. Go to Radio Shack and purchase a new plug and install a new plug on the cord.
3. You can also take the headphones apart and cut a few inches off the cord where it connects to the right speaker and reconnect the new end of the wire to the right speaker. The goal is to cut away the bad part of the cord and re-attach the good part back.
4. You can try to replace the entire cord but I haven't been able to find replacement (THIN) cords too easily.
Good Luck,
- Jim
Jan 24, 2008 | Radio Communications
Pioneer AVH-P5700DVD Car DVD Player Logo
41 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
