Power on projection tv will not stay on, Pioneer SD-P4565 projection tv
When you turn the power on, the tv will come on and run for 10-15 minutes and then just go off. If you wait 10-15 minutes you can turn it on again with the same results.
  • 4 more comments
  • dkendrick Jan 20, 2008
    The big screen is a Pioneer SD-P4565
  • dkendrick Jan 21, 2008
    do you know where I can pickup a low voltage regulator if the soldering doesn't work?
  • dkendrick Jan 23, 2008
    while messing around with the board, I knocked the top off what looks like a J 471, its blue plastic about the size of a small button. It sits on space VR181 on the power board. Any idea what it is and where I can get another?
  • dkendrick Jan 24, 2008
    Thanks-you have been great help. Its been since the early 90's since I have messed with transistors. I don't remember much. I have a good meter, just point me in the right direction.
    Thanks again.
  • dkendrick Jan 25, 2008
    my email is, Thanks for the help.
  • skipt98 Dec 28, 2008
    how do you program channels on an pioneer SD-p4565 we do not have a remote for it and the menu is a little confusing
HI i have a samsung HL-R5078WX/XAA, i seem to be having the saem issue. but wiht my t.v. it turns on. for about five seconds. then stops, recycles trys again. but no picture loads, and about after 8 cycles. it shuts off. and the lamp(green), timer(green), and the stadyby/heat(red) lights start blinking. and there is a louder than usual whining like a fan. but i know its not the fan because i unplug the fan and its still making the noise, like a medium to high pitch whining.
help please?
Posted on Mar 12, 2008
  • 8,617 Answers
What model tv do you have?
Posted on Jan 19, 2008
  • 3 more comments
  • Sonny Berry
    Sonny Berry Jan 20, 2008
    It sounds like its going into protective shut down mode. Let me do a little research and I will get back to you.
  • Sonny Berry
    Sonny Berry Jan 21, 2008
    you probaly have a faulty low voltage regulator that is faily when it gets warm or possibly a bad solder joint on the power or deflection circuits. I would look for bad solder joints first as this set is over 10 years old.
  • Sonny Berry
    Yes just give me the numbers off the transistors and i will provide a link to where you can get whatever part you need online with fast shipping. I have alot of electronic distributors that can even deliver overnight if you require.
  • Sonny Berry
    Sonny Berry Jan 23, 2008
    The part VR181 is a variable resistor. The markings are j471 it actually means you need a 470 variable resistor at 5% (J). as far as the voltage regulator you will have to give me he numbers on theregulator itself then I can locate one for you or its industry tandard substitute. Hope this helps. Are you famillar with the proceedure to test NPN and PNP transistors? Let me know.
  • Sonny Berry
    Sonny Berry Jan 24, 2008
    post your email and i will send you some software that will tell you how to check transistors, and it has a neat little feature where you can type in the number of the transistor and it will list all the subtitutes for that trans.
Sd-p4565 turns on but no picture
Even though this is powering up you still need to eliminate the power supply board. You will have to put a meter on the outputs and get a measurement. I would bet it is your power supply though.
Jan 07, 2013 | Pioneer Televison & Video
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer 5065 tv
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like, to buy a refurbish power supply board for the replacement. Good luck
May 25, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
If the sound keeps working your probably just need a new lamp, if the sound does not stay on, you probably to get someone to fix the power supply.
Sep 02, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-P5181 will not power up
pioneer sd p5181 will not power up redlight on stand by works when i hit the power button makes a funny sound and then nothing anyone plz!!!! help thnks
Jul 11, 2009 | Pioneer Televison & Video
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Pioneer SD-P55A5 Shuts off and must be reset with Main Power Switch
if you are not a tech take your set to be repaired your tv illness is in the power supply or related circuit.good luck.
May 14, 2007 | Pioneer SD-P55A5K 55" Rear Projection...
Televison & Video Logo
371 people viewed this question
Top Televison & Video Experts
