Question about Dell Inspiron 2600 Notebook
Need a manual showing keyboard for Inspiron 2600 Model PP04L so I know what each key does.
  • 3,940 Answers
Dell 1703fpi
Dell 1703fpi LCD monitor,
http://philadelphia-pa.americanlisted.com/computers/dell-1703fpi-17-lcd-monitor-vgadvi-usb-hub-50-phoenixville_21225579.html
I got that part Dan.........
What I need is what Model Number of Dell Inspiron it is.
This is on the Bottom of the Inspiron laptop.
Why?
Because I do not know if the Dell Inspiron laptop you have, has a DVI port, or a VGA port; for an external monitor......
Generic information while I wait.........
Example of Digital Visual Interface port, and corresponding cable,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Example of Video Graphics Array port,
http://en.wikipedia.org/wiki/VGA_connector
Can be on the side, or back of laptop.
Laptop OFF, monitor OFF, connect the matching video cable from the external monitor; to the laptop.
Now turn the laptop on.....
By factory default settings, the display should now show on the external monitor. (Dell 1703fpi)
No?
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
Press, and hold down on the Fn key. (Usually 2nd key from left on bottom row of keyboard)
AT THE SAME time tap once on the Display Toggle-Over key.
Which one is that? Dunno.
Laptop model number was not stated.
For a Dell Inspiron though, it's usually the F8 key.
(F1 through F12 keys at the top of the keyboard)
Hold the Fn key down, and at the same time tap once on the F8 key.
Still no?
Hold the Fn key down again, and tap once more on the F8 key.
IF, F8 is the correct key for Display Toggle-Over, and there is no display on the external Dell 1703fpi; then I suggest you have a problem with the video chipset; on the motherboard.......
Awaiting reply in a Comment.
Regards,
joecoolvette
Jul 03, 2013 | Computers & Internet
F keys do not work f3,f4,f5,f8,f9
You will need to replace the laptop keyboard, go to www.ebay.com Type: make and model of laptop, refine search to keyboard. It would not hurt to use an external keyboard to be sure.
Apr 30, 2012 | Dell Inspiron 15 1545 Notebook
The F8 and F9 keys on my Dell Inspiron 1525 are messed up. Do you know where I might purchase those two keys from?
Dell is notorious for shipping several different types of keyboards (as far as the tiny parts under the keys are concerned) from different manufacturers. While the entire unit fits and plugs in exactly right, chancing replacing keys is risky. I speak from experience having repaired 100's of Dell laptops.
I recommend buying a new keyboard from one of the vendors at the link below. Then go to Dell support and you'll find your Service Manual there to replace the keyboard. It's relatively simple.
It's worth the 15 bucks...believe me
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=dell+inspiron+1525+keyboard&_sacat=See-All-Categories
Best Regards,
Marcus
Sep 14, 2010 | Dell Inspiron 1525 Laptop
My L button on my keyboard is showing three and so is some other letters they are showing numbers instead of letters
You probably have accidently turned on numlk which turns mjkluio789 into 0123456789
Most laptops require a two key combination of Fn (function key) and NumLk (numeric lock key) to toggle it off and on. Sometimes there is a seperate NumLk by itself as it is on most desktop keyboards.
If this doesn't do it let me know the make and model of your laptop and I'll see if I can help further.
Sep 10, 2010 | Dell Inspiron 8100 Notebook
Popped a key off my Dell Inspiron laptop keyboard by accident.
You should be able to just pop off another key from your keyboard using a flat screwdriver. Then just compare how that key looks and reassemble the plastic components and the key just snaps back on. Also you may want to check your warranty at support.dell.com under warranty status and enter your service tag. If you are under warranty dell will replace it. Also ebay dell keyboards are cheap to buy and easy to install just two screws and a simple cable. If you need more help let me know.
Nov 30, 2009 | Dell Inspiron 6400 Notebook
I cant write in my keyboard dell inspiron
If you are not able to use the integrated keyboard, you can try an external USB keyboard. If it doesnot work, then you can try to use the onscreen keyboard. To use the onscreen keyboard, go to start > programs>accessories>accessibility> on-screen keyboard . Open a notepad and then try to type using the onscreen keyboard. If it works, then you need to replace the keyboard.
Nov 09, 2009 | Dell Inspiron 2600 Notebook
Keyboard need driver
i will get the link for you to install the keyboard
Apr 19, 2009 | Dell Inspiron 5100 Notebook
Dell Inspiron E1505 Keypad problem
Refer to the link that shows the way to solve this issue :
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
Hope u could fix it urself :)
Nov 12, 2008 | Dell Inspiron E1505 Notebook
HOW TO DO A COMPLETE RESTORE USING THE KEYBOARD
Just hold down CTRL and start taping f11once you hit the power button.this would start th dell pc restore and would take the system back to day one.
Dec 23, 2007 | Dell Inspiron 2600 Notebook
Can I disable deffective Keys?
There are a number of utilities with that function. I ran into one, Winkey Killer, at www.nonags.com. (At least, I assume that is its function.) also, this may help: http://www.microsoft.com/whdc/device/input/w2kscan-map.mspx
Mar 20, 2006 | Dell Inspiron 2650 Notebook
Dell Inspiron 2600 Notebook Logo
75 people viewed this question
Alun Cox
