Question about Motic DMBA 300 Binocular Microscope
Once the stage is adjusted it comes down slowly
  • 45 Answers
Tighten the screws of the coarse adjustment. You must disasseble the coarse adjustment knob (i.e. remove the plastic caps) in order to do this.
Posted on Dec 11, 2009
Testimonial: "goood suggestion "
4 Suggested Answers
SOURCE: Stage slowly falls causing unfocus
Try holding the Right knob so it does not move, whilst firmly moving the Left knob towards you (clockwise), this is the adjusting method used on Zeiss Jena 1960's High End microscopes, e.g Eduaval & Ergaval.
Good luck,
Alan Mowle
Posted on Mar 20, 2009
  • 45 Answers
SOURCE: tip to adjust the moving stage
Tighten the screws of the coarse adjustment enough so it starts generating enough friction to hold the stage again.
  • 36 Answers
SOURCE: stage slides down after focusing
There is a tension adjustment for this. It is located on the coarse focus knob which is on the same side as the switch. It looks like a chrome ring with about 3 holes in it. A strange looking tool should have come with the scope. It is designed to fit into these holes and allow you to adjust the tension on the coarse focus knob. You need to tighten it just a little bit. Not too much or you will have trouble operating the coarse focus knobs smoothly.
Posted on Dec 25, 2010
Impeller does not rotate consistently and powerfully enough
check belt then check and adjust tension
it can be done on idler pulley or the cable going to handle for auger drive
Jan 01, 2014 | Craftsman 26" 208cc* Dual-Stage Snowblower
Stage slides down after focusing
Jul 08, 2010 | Swift M2251C Monocular Microscope
My stage is no longer moving with the knobs.
With one hand push the stage down, and with the other turn the coarse adjustment down. It's a cog alignment issue. The coarse adjustment cog should be turning in order to catch the stage track.
Feb 19, 2010 | Celestron 44320 Trinocular Microscope
Tip to adjust the moving stage
Dec 09, 2009 | Science & Laboratory
Screen only flickers, power light blinks slowly
Need to change or repair monitor at this stage.
Sep 07, 2009 | Computers & Internet
Cressi sub ellipse titanium reg is free flowing
Hi. I would suggest having the internal o-rings checked. One of them could be worn, allowing the air to escape. Or put it into your local dive shop for a service.
Apr 06, 2009 | RTO Cressi-Sub Ellipse Titanium/MC7...
Good luck,
Alan Mowle
Mar 05, 2009 | Science & Laboratory
Adjusting front derailer
Typically adjusting the front derailleur is a matter of adjusting the two adjusting screws on the derailleur. So turn the bike upside down. It should sit on its seat and handle bars. Find the two adjusting screws one will prevent the derailleur from traveling too far out preventing the chain from coming off. The other screw prevents the derailleur from traveling too far in keeping the chain from falling off that way. Now once you have found the screws slowly start turning the pedals like it was being ridden. Move the derailleur out as far as it will go if you see the chain is about to come off adjust the screw. Do same for inside screw. Now move the back derailleur all the way in and retest front derailleur, repeater with rear derailleur all the was out. Hope that helps. Oh, the back derailleur adjusts same way.
Feb 27, 2009 | Shimano Brake Cables Atb Mountain Bike...
Problem with MF-02 binocular microscope stage
I think your problem lies in the way the stage is limited upwards. On top of the stage, right behind it where it slides against the arm, there should be a little screw.  This screw limits the movement of the stage to a certain point upwards.  If the limit exceeds the adjustment gear and its opposing track, then the stage just goes up one notch and then it clunks down.  If you screw it down the stage is limited further down, if you screw it up it's limited a bit higher.  The point of this screw is to prevent objective and slide damage.  Try adjusting this little screw a bit further down and see if it still 'clunks' when you turn it up.  After that we may work on properly adjusting it.  If not, please post again with whatever detail you can provide to aid you with this problem further.
May 28, 2008 | Premiere Microscopes MF-02 Binocular...
Microscopes
sir,
Diffrent company having their own system for microscope arm balacing.
Tell me which one microscope you have.
Auxillary arm or microscpe body sloly come down ward.
tell me problem is consult with which part..
INDRAVIJAY
Jan 02, 2008 | Tasco 750 Monocular Microscope
Motic DMBA 300 Binocular Microscope Logo
128 people viewed this question
Top Motic Science & Laboratory Experts
S J Parkin
S J Parkin
ray gallant
Tom Chichester
Are you a Motic Science and Laboratory Expert? Answer questions, earn points and help others
