Question about Kenmore Oasis HE 27082 Top Load Washer
I need a part (Interface)- part number 26-110-85643992, also the control , part number-26-110-w10189966 of my Oasis HE
  • 5,911 Answers
Any one of these websites should carry the parts you need for your Oasis:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also have helpful exploded view parts diagrams to assist you in identifying parts.
Prices vary between these sites, so shop and compare. If you have any further questions about this repair, please let me know. I hop this helps you.
Posted on Dec 09, 2009
What part needes to be replaced when receiving F1 code on a kenmore 110 27072602 model?
Hello, welcome to FixYa
Based on your description I'd first suggest you look up your warranty coverage in the owners manual to see what degree of warranty the control is covered before replacing the control board.
I say that because according to Whirlpool, (they manufacture the Kenmore Oasis as you may or may not have known) this is the definition of the "F1" error code:
Primary Control Failure
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly. i.e.
Part # is W10189966 and available at "searspartsdirect.com" "repairclinic.com" to name a couple. Let me know if I can help move you forward in an many and I''ll certainly do what I can.
**You may also want to look into recalls on those control boards as well as many of them where recalled in the last year or two...you'll need to phone the manufacturer and present the model and serial number of your machine.**
Thank you for choosing FixYa today sand good luck. Please take a second to rate the info provided here for you today and good luck.
Regards,
Macmarkus :)
Oct 27, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Can wash my clothes washer is giving a f1 announcement and stops.is a kenmore elite oasis model 110.27032602 quiet pak 2.thanks
The F1 error code means that the control board has a detected a problem within the control itself and the control board would need to be replaced.
The part number for that control board is W10189966 it could be picked up at your local appliance parts store or online at;
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Oct 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis washer, top load that flashes F1 at the rinse cycle, what part do i need to fix this???
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it.
The first image below shows the method for accessing the pressure transducer tube that runs from the bottom of the washer tub to the machine control. I recommend checking this air hose for pinches, twists or crimps.NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced. The procedure for accessing and replacing the machine control board is shown in the second image below. The part number for the machine control board is W10189966.
Image 1
Image 2
Jan 09, 2011 | Kenmore Washing Machines
Kenmore elite oasis he keeps flashing f2 and beeping
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
The procedure for replacing this control board is shown in the images below.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis washer kenmore elite, the end of cycle signal button toggles back and forth from soft to loud all on its own continuesly. what could be the problem?
This is a common and very well known problem with the Oasis. You will need to replace the operator/user interface board inside the control panel to resolve this issue. The board is located directly behind the control knob. You can usually order the part at any of the following websites:
repairclinic.com
Just type in your model number and look under the "Control Panel Parts" heading. If you do not find your model number listed at some of the websites, use the part number you obtain from the Sears websites and do a Search by Part Number. You should find the part listed at the other sites. Sears tends to have a more extensive data base of model numbers, but may not always have the better price.
To replace the user interface board, follow these steps:
1. Unplug the washer.
2. Locate and remove the retaining screws in the back of the control panel. With the screws removed, the control panel will lift from the back first, then off. NOTE: Be careful when lifting the panel, there is a small interface cable plugged into the control board.
3. Remove the interface connector and pull the control knob off.
4. Lay entire panel face down on a soft surface (such as some folded towels).
5. Remove the user interface cover (this is item 10 if you use the drawings in the Sears website).
6. With the cover removed, take a small flat blade screwdriver and pry back the tabs that hold the board in place. There will be several around the entire perimeter.
7. Once the old board is removed, carefully insert the new control board making sure you don't put it in upside down. Mark the location of the interface connector plug as a reference. NOTE: Do not handle the surface area of the board with your hands. This can cause damage to small components of the board and render it unusable. Hold the board by the edges.
8. Reinsert the interface cover and flip the control panel over to its upright position.
9. Reinstall the control knob and make sure you plug the interface connector back in.
10. Reinstall control panel by inserting the front edge of the panel into the grooves on the washer top casing and lower it back. Tighten all mounting screws.
This is a pretty simple repair job. The hardest part you may encounter is removing the old board. The small tabs can be difficult to bend sometimes. Also, use care not to apply too much pressure on the new board when you install it. They can be difficult to snap back into place at times. Just take your time.
If you have questions along the way, please let me know. I hope this corrects your problem.
PS You may also try unplugging the washer and removing the control panel and try cleaning the interface connector to see if this helps BEFORE you order parts. Sometimes it helps.
Feb 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Oasis washing machine keeps beeping during the wash cycle..
Jan 21, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 code on oasis washer, machine will not work
HI. This code is in reference to a failed Machine/Motor Control & Water Pressure Transducer module. This is the main initiator of the unit. The F1 is and indication of a failed component, or circuit board structure.
This module must be replaced, asap. The part number will be
W10189966. Click here to view an exploded diagram of the control sector. This module will be located just under the control sector panel housing. The affected part will be labeled number 1
Jan 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis Model# 110.27087603
I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
Oct 29, 2008 | Washing Machines
Kenmore oasis washer
This is a common problem with the Oasis. The problem is the User Interface Control board behind the control panel. There's a relay on the board that shorts out and causes the washer to randomly (and constantly) beep. This can also occur with the washer turned off. Since the circuit board is not serviceable it is recommended that you replace the control board. Searspartsdirect.com carries replacement parts for your washer. Just type in the model number and search under the console heading for the user interface board. If you are usure which part, I'm talking about, please post back with your model number and I can assist you. I hope this helps.
Aug 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
148 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
