Televison & Video Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Every time i turn on the 22 lcd technika tv the screen flashes up normal then the screen goes off and can't see anything
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Dec 09, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3734630
Points
36074
Is the bulb still lit? Have you checked power to the ballast with a volt meter to see if power is going to bulb and ballast? You can check power coming from power supply or high voltage transformer to the main board with a voltmeter as well. You could likely have bad capacitor or transformer but those will need to be tested with an ohmmeter in the ohm setting to check for continuity
Technika 22-700 standby light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Poor contrast
Check its back-light CCFL lamps.
1helpful
2answers
22" LCD T.V. Model M22/20A-GB-TCDI-UK Code
Sky Media UK Provides services for this brand of television please email [email protected] with your model number and they will be able to assist you further or call them on 0871 2000 463
43helpful
3answers
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Flashing screen when i first turn on my... but turns black immedi
You could have a faulty inverter board or faulty CCFL lamp which can cause the screen to flash.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
2answers
Flashing screen when i first turn on my SamsungSyncMaster 2232 bw
I had a similar problem with my LCD computer screen. I took it apart and noticed a capacitor that was raised up on the flat end and appeared to be leaking a substance. Replaced it with a similar capacitor and works fine, for three years now.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
