Question about Kitchen Ranges
Older model Vulcan propane gas range/oven
Trying to determine if the service guy gave the right answer - stove runs intermittently - service guy said there was a "bad seam" and it is not repairable?  Stove is about 12 y.o.
  • 640 Answers
Im a hobart tech and service these ranges regulary,hobart owns vulcan---tell me your problem
Posted on Jan 28, 2008
6ya staff
SOURCE:
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
Sep 02, 2017 | Kitchen Ranges
Pressure regulator gas
need to leak test ALL lines and connections --most lp companies have a service person/company to do this they have the proper equipment to test and repair if needed
Jun 02, 2017 | Magic Chef Ovens
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 10, 2011 | Vulcan G36L Gas Range
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
A customer has a commercial propane gas stove,
Faulty thermostat, can be the only reason if the burners on the top are okay and don't fluctuate. That proves your regulator is fine. You could also check the line somewhere with a pressure gauge, or manometer.
Sounds like they need a new rep. Contact the company's service department. These guys have often come across the problem before, "oh yes, we had a batch of thermostats that had faults about 4 years ago. We didn't do a recall because it wasn't a safety issue". Meanwhile, the rep is only after sales and commission.
Aug 08, 2017 | American Range ARW36-6 Stainless Steel...
I have a vulcan VG36-66. We turn off the oven and
if your oven is automatic check the clock is in manual.
Sep 28, 2009 | Stoves 36" VULCAN RANGES GAS(CLICK HERE):...
Coverting a Vulcan 260L commercial range to Propane
Yes you can convert to LP gas. go to this web site to get the parts.
http://www.vulcanhart.com/manuals/F-30536.pdf
Go to page 9 and look at parts # 57 - 60 that is the part you need to change. You need to know the sea level that you are at though so you get the right part.
Now if you go to page 8 you will find where it goes part # 53 thru 61
To order the parts go to this web site
http://www.vulcanhart.com/parts.cfm
If any ? please fill free to ask.
Dec 17, 2008 | Vulcan 260L Gas Kitchen Range
Kitchen Ranges Logo
557 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
