Question about Hoover Vacuums
Model S1361 series ZA8.o; how do i disassemble to replace power cord?
Problem displey dvd ns 530
Posted on Dec 09, 2009
How do i open a hoover vacuum cleaner
Leave this to a professional. You can set the house on fire with a shorted out vacuum.
Jan 30, 2014 | Hoover S1361 Bagged Canister Vacuum
Vacuum not working
Check cord, switch motor etc.
Jan 15, 2014 | Hoover S1361 Bagged Canister Vacuum
My kenmore progressive caniser needs a new power cord. the plug had one of the metal prongs break on the plug. how can I replace the cord? model 22812201
I do not know if you want to replace the replace the power cord or the receptacle for the power wand?
If you need the prong for the power cord you can purchase a replacement power plug from a local hardware store and it will function and look reasonable. If you want it to look like the original factory plug you can purchase the plug from the following link for $29.56 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=4370695&productGroupId=0020&supplierId=116&mv=rr
You could also purchase the cord and retractable reel if you want to make it easier for $53.38 plus shipping by clicking on the following link.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8192087&productGroupId=0020&supplierId=116&mv=rr
Clicking on the links below will show the exploded parts view so you can see how to disassemble the unit to replace the cord.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00003.png
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00001.png
If you need the power wand plug click on the bellow link for $21.99 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8175251&productGroupId=0020&supplierId=116&mv=rr
I hope this helps and is the information you needed.
Jun 22, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Power cord leaks green oil
I suggest that you replace that corroding internally power cord. It may not be safe to use that power cord.
You can get your model information, at the bottom of your vacuum canister, from underneeth, where the water pan attaches to it.
It is probably a D3, or a D4
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Apr 10, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Cord is stuck out full length
Not sure if you're posing about the Hoover since you're in the Hoover S1361 forum, or the electrolux.
I had similar frustrating problems with my hoover and made a blog post on how to take it apart and fix it here.
Jan 18, 2009 | Hoover S1361 Bagged Canister Vacuum
The vacuum does not turn on when plugged in.
It could be either the switch, the motor, or the cord reel. Try plugging it in and slowly feeding the cord in and out while clicking the power switch on and off. If the motor kicks on while doing this, you have an intermittent short in the cord reel.
If you remove the bag chamber lid, (on the s300 series merely opening it until it makes an awful cracking sound, and then lifting it off; on the s500 series you'll have to gently pry the tab just inside the hinge away,) you will be able to access the screws to remove the rear housing. Under the exhaust filter are two screws that will allow you to remove the control unit, and then there are about five screws on the top that will need to be removed if you need to go further.
The control unit contains the switch, (in many models, but it depends on your model...) which you can test continuity through by using a VOM. If the switch checks out ok, you can test continuity through the other electrical components on the underside of the control unit. If you find a component that does not have continuity, replace it. If they all appear functional, continue with the disassembly:
On the s300 series it is easiest to flip the machine upside-down after removing the top screws, and then lifting the base away from the top housing. This will give you access to the motor and the cord reel. On the s500 series you will just have to lift the colored plastic body up and away from the base.
What can occasionally happen with these cord reels is that they can wear out, allowing too much lateral slop of the actual reel assembly. You can shim this by using something on the axle in the center to push the reel assembly back against the contacts. I use a small rubber "doughnut," but pretty much anything non-conductive will do the trick.
If this doesn't restore electrical continuity, you'll probably need a new cord reel. I highly recommend against trying to do any further repairs on the cord reel itself, as it's a nightmare to deal with... especially if the main spring comes apart. Miele does not recommend replacement of any component of the cord reel, only the entire cord reel assembly.
Any other problems will have to be referred to a repair station, since it could then be either the motor or the motor control board.
Do NOT attempt to test the motor by directly connecting it to wall voltage, as the actual power applied to the motor when it is functioning is stepped down by the circuits attached to it, and attempting to "hotwire" it will fry the motor.
Hope this helps,
-R
Aug 09, 2008 | Miele Vacuums
Replace power cord
http://www.rainvac.com/schE1.pdf
Jul 17, 2008 | Rainbow 75th Anniversary Canister Vacuum
Hoover S1361, getting it apart
Hi guys,
It was frustrating as hell for me when I tried to get it apart. I have a blog post on how to do it. Hope it helps!
Taking apart the Hoover S1361
Jun 26, 2008 | Hoover S1361 Bagged Canister Vacuum
Pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Jan 08, 2008 | Hoover S1361 Bagged Canister Vacuum
Vacuums Logo
190 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
