Question about Lasko Heating & Cooling
Lasko Heater (model 760000) wont turn on!!!
Hello!!
I bought a Lasko CYCLONIC CERAMIC HEATER WITH REMOTE CONTROL AND FRESH AIR IONIZER (Model 760000) last winter and it worked GREAT the entire winter. I stored it in the closet over the summer and plugged it in this past week as it's getting cold again. The heater doesn't heat up at all and shuts off automatically within a minute of me plugging it in. I have tried unplugging it for a whole day and trying the next day and still does the same thing!! Is it scrap or is it fixable?? Please help!!! I'm FREEZING!!! Lol!!!
--Michelle
SOURCE: Blinking lights. Shuts off.
Hello, Mne was also shutting down. Turns out that is was clogged with dust, therefore overheating and turning it self off. If you're handy, you may want to open the heater and dust it off with a can of compressed air.
Worked for me.
Posted on Nov 20, 2008
johnsonr1
  • 91 Answers
SOURCE: Cost per hour to run Model # 5840 heater
take the wattage of the heater, divide it by 1000 then multiply that by your cost per KW/hr from your electric bill, then multiply that by the number of hours you operate the heater. That will give you the exact cost to operate at full heating per hour.
Posted on Nov 04, 2009
SOURCE: I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Posted on Nov 18, 2009
  • 5 Answers
SOURCE: Portable Heater keeps turning off
I just fixed my Stanley Lasko 675900 FOR GOOD and would like to tell the world how to fix it!
1. Remove the front plastic grill. The bolts are torx heads with a center pin. You may be able to find a torx head driver with the center pin but I improvised. I Used a dremel tool with a small rounded diamond bit to grind the center pins out of each screw so I can use a standard torx head driver on the screws.
2. Remove the heating element. These should be Phillips screws.
3. Blow out the dust from the back side of the heating element. (be careful with the fragile fins)
4. put it all back together and it should work just fine.
5. (optional at your own risk!) I believe the small gadget attached to the top of the heating element with the white wire is the limiter. You can use pliers to slide the unit out of the element and either move the unit further toward the center area, or cut the device out completely with wire cutters and then splice it back together. If you do this REMEMBER TO CLEAN THE BACK OF TH HEATING ELEMENT EVERY MONTH TO PREVENT A DUST FIRE!
I hope this work for you and good luck!
Posted on Jan 27, 2011
  • 946 Answers
SOURCE: I have an All-Pro 115,000 btu kerosene heater,model number, R115d(T)I can turn it on but it will only run for about 3 minutes, it shuts off and a big cloud of black smoke appears,
Is the fuel tank cap vent clear? Are you sure there's no water in fuel tank? don-ohio
Posted on Jan 05, 2017
Knob for a Stanley model 675919
Hello, Sean -
I hope I am safe to assume you need to find a replacement knob for a Stanley brand Pro-Ceramic Utility Heater with Pivot Power Model 675919. If so, I refer you to Lasko, the company which manufactures that heater under the Stanley brand name. This is the number to call the Lasko Parts and Accessories Customer Service Department to find out if they supply (sell) replacement knobs for your unit:
800-233-0268 (Monday - Friday, 8am-5pm, Eastern Time zone)
Best wishes
Dec 18, 2017 | Stanley Air Tools & Compressors
How do you set thermostst
Open the units door, set temperature 5 degrees above the room temperature or OAT.
Oct 04, 2014 | Lasko Products 760000 Ceramic heater w...
Lasko ceremic heater hot cord and melting
Yes it could be the outlet or the more likely wiring to it. If your apt has a maintenance preson have that person take a look if not call an electrician.
Dec 03, 2013 | Lasko 760000 Cyclonic Ceramic Heater, 750...
I lost my owners manual & would like to know how to turn & operate my lasko ceramic heater. Thank you in advance. Roy Reyes
Follow this link:
http://www.laskoproducts.com/heaters/heaters.html
and put in your model of heater. Once on your models page, the link to the manual is near the bottom of the page, a red link.
Mar 15, 2011 | Lasko Ceramic Heater
How do you clean the ionizer in a lasko wind curve
You have to take the fan apart. They didn't design it with the convenience of the customer who likes to keep things clean in mind, so you have to get out a bunch of screwdrivers and stuff and roll around on the ground and fight with it until you get it apart. I posted a lengthy post on how to get this model apart, as I just did mine yesterday. Just look for my name on the Lasko models like this one. But be careful and don't try it if you don't think you can pull it off without getting hurt.
Jun 11, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
Dec 27, 2009 | Lasko 5130 Ceramic Compact Heater
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
How to clean filter on Lasko tower ceramic heater
Thanks for the response = I blew the filter clean with a forced air canister.
Nov 29, 2008 | Lasko 5540 Ceramic Compact Heater
Heating & Cooling Logo
355 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
