Question about Electronics - Others
This 78 rpm has a piece broken cleanly out of it. How can I attach the piece so that I can play & tape the record and then put it away?
  • 5,626 Answers
The only way to do it is with superglue. You need to be very careful and apply it very lightly to the pieces possibily with a small sewing needle. Very fiddly work. I repeat tiny amounts of glue, otherwise they will cause a blob. You might need to test any glue on a record that has had it. Just to make certain the glue won't attack the plastic.
Posted on Dec 13, 2009
How to record a cassete tape
Typically, to record on a cassette tape you must press BOTH "Record and Play" buttons at the same time and the tape recorder will begin to record.
Nov 26, 2014 | Audio Players & Recorders
VCR will not record
VHS tapes have little tabs on the side of them. They are located on the side pointing out when you put it into the VCR. If the tab is broken of it will not work to record anything. It tells the machine that the tape all ready has something on it. If you want to record over something you can usually put a little piece of paper in the hole of the missing tab and piece of tape over it you should be able to record.
Nov 18, 2013 | Quasar Televison & Video
Was given an Ampex AG-440 tape deck that stopped recording after sitting for about six months. Any ideas? (I lost the Manual) Everything else works fine. When put into record mode all lights are lit...
try cleaning the record head, Most people only clean the play back heads on tape players, the record head is just off to one side of the main playback heads , you can use a Qtip and rubbing alcohol to do the cleaning
May 21, 2011 | Audio Players & Recorders
What is required to convert 78rpm records to mp3 format?
The cartridge must have a stylus for 78rpm records. If the turntable does not have a 78 speed play it back at 45rpm. Record it and using the software you have or get one such as Audio Cleaning Lab, just select the option to convert from 45 to 78. You can then carry out any audio modifications to clean it up, then save it as an MP3.
Never use a 45/33 stylus to play a 78 and never use a 78 to play a 45/33 record.
Nov 07, 2010 | ION Audio TTUSB10 Turntable
Audio cassette tape broken. How do I repair?
Radio Shack used to sell a splicing block and tape for fixing broken tapes. They may still, and you can order online from other sources.
You need to pull the tape out from the cassette a little way. Overlap the tape sections a little and get them aligned, which is what the splicing block is for. Cut across both pieces and take away the scraps. This makes sure the pieces match up. Lastly you place special splicing tape over the join and trim the edges. You need the special tape, since it's designed so the adhesive won't ooze out and get on the tape recorder heads.
If the tape has come loose fro the hub inside the cassette, you need to open the housing and use the splicing tape to fasten the recording tape (actually the plastic leader tape) back in place. Depending on how the cassette was made, there may be screws holding it together, or it may have been glued. Some commercially-made music tapes and bargain-grade cassettes weren't made to be opened. If you do open the tape, don't lose the little metal piece with the felt square that goes across the opening behind the tape. This is the pressure pad that keeps the tape pressed against the head in the recorder. Without it, the tape won't work properly.
Apr 12, 2010 | Electronics - Others
We put a tape in vcr. we push record and the vcr ejects tape and shuts off.
Does the tape play normally? Does this happen with several tapes when you try to record? Check the record protect tab on the lower left hand side on the facing end of the tape. If this is broken or bent it will not record, you can put a piece of tape tightly across the tab as a repair
Oct 01, 2009 | Philips Televison & Video
Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
Aug 13, 2009 | Samsung Televison & Video
Dictaphone indicates end of tape
The sensor that detects the tape movement is bad and will need to be replaced.
Nov 10, 2008 | Dictaphone 2741 Desktop Cassette Voice...
Electronics - Others Logo
55 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
