Acoustic Image Contra series II - No audio passing through preamp - Need schematic and parts list. The amp was overdriven due to bad ground in guitar. The amp powers up, but no signal is heard.
I decided that without a schematic and parts list I shouldn't even attempt to repair it. I had taken the cover off and disconnected the control board from the amp. When putting it back together to return to owner, I noticed the plug and socket for the control board did not go together properly. After a little maneuvering, I managed to get then joined, and just like that the amp was working again. I suspect that who ever had repaired the ground on the guitar had opened the amp up as well, and just didn't get it back together properly. The amp wasn't really damaged, after all.
Posted on Dec 10, 2009
Takamine TP4T Preamp blinking
It does sound to be fried but, you really don't have to replace it with the same exact model, look for an upgrade, I'm sure that manufacture and many others have one better. If it were my guitar, I would definitely think of it as upgrade time. The pickup is probably ok knowing that it can handle heat better due to its location and materials.
Mar 09, 2014 | Takamine 1 NEW Takamine EG350SC G-Series...
Where to buy TP4T pickup
You can try repair it. They are pretty basic. I would look for poor solder connections, and reflowing all solder joints in it would be prudent.
The hum is likely from a gain stage with a bad solder joint on the input isolation capacitor. Also check other wires and check for bad solder connections on the pickup connections as well. It can even pick up hum through a bad shieid/ground connection in the jack on the guitar
Mar 29, 2012 | Takamine 1 NEW Takamine EG350SC G-Series...
Hi i recently bought a Takamine EG 260c G Series acoustic electric Guitar with TP-4T preamp installed in it. Now the problem is when i connect my guitar to an amplifier, the sound comes through it only...
That is working backwards from what it should be. I suspect a wiring error. Since this is a recent purchase, do NOT risk voiding your warranty. There isn't any real good documentation on the tuner.
I am not sure which tuner you have HOWEVER with one type, the FIRST press will turn on the tuner with the sound going out as well till the tuner goes off. The SECOND press silences the sound and is tuner only, the THIRD press turns off tuner and passes the sound. This is different than a lot of tuners and you will need to do three presses to restore sound instead of the usual two.
May 02, 2011 | Takamine 1 NEW Takamine EG350SC G-Series...
Hi, I have an RBX 374 and I cannot get any sound from it. I have got the wiring scheme but the wiring looks O.K. Some say it might be the pre-amp. Does anyone know what could be the problem...
i dont' see where this model has active pickups (guessing this is what you mean by pre-ampped).
The issue can be in a few places.
1) the strings could be too far from the pickups and the instrument needs to be tuned.
2) the pickups are bad
3) your jack is bad
4) the cable is bad
5) your equilizers are not corrected
6) your volume control is turned down or damaged
7) your amp is damaged
this is a small list of the basic possibilities.
Mar 29, 2011 | Yamaha Rbx374 4String Electric Bass Guitar
I've owned a Roland AC-90 acoustic guitar amp for 8 months and am having problems with the XLR mic preamp. There is some very low-level output with the volume fully advanced, and with an external...
I don't have the exact schematic... however sometimes they have RF bypass capacitors to ground on the balanced input lines and one side gets shorted. The schematic I do have is for an AC100. It shows a rather unconventional input circuit. You can download it here and it MIGHT be close to your unit:
http://elektrotanya.com/roland_ac-100ut.pdf/download.html
I note that this unit does NOT have Phantom power so you CANNOT use a condenser type mic with it unless you use a preamp with Phantom power... Maybe that is the problem?
Feb 16, 2011 | Roland Ac-90 Acoustic Chorus Guitar Amp...
When i plug the guitar into the amp, i turn the preamp on, and it allows me to play for about 90 seconds and then cuts out and no sound comes out of the amp until i turn the preamp back on.. what do i do?
If the preamp is in the guitar, the battery is likely dead. When a dead battery "rests" for a short while it recovers a bit and may operate for a short time and shut down.
Jan 10, 2011 | Takamine EG361SC Acoustic-Electric Guitar
I bought my Taylor acoustic/electric brand new. It sounds great, but when i plug it into my amp no sound comes out. I replaced the battery, but it still failed to work. When i plug it in to the amp and...
If you just bought the guitar, take it back. Taylor has good warranty programs, take it back to the dealer. You may have a bad connection inside where the saddle pick up plugs into the graphic preamp, the fact that you hear a sound when you put the battery in or out indicates very little. You may have a bad preamp, like I said, if its new, don't wait get it back to the dealer or contact Taylor.
Dec 27, 2010 | Taylor Guitars 816ce Acoustic Electric...
Roland AC90 crackles when using a slide.
It is because the AC-90 is not grounded. If you look at the power cable, there is just + and -, no ground/earth. This is because ground is not usually needed when using acoustic guitars/ mikes. If you use an electric guitar, or a slide, there will be problem. I have a AC60, that does go to ground. No hum. AC90=hum. Can probably be fixed by attaching new power cable and soldering earth to the chassis, like on the ac60.
Jan 27, 2009 | Yamaha AX-596 Amplifier
239 people viewed this question
 Grubhead
Grubhead
