Satellite battery problems
Battery was not charging so \I bough another one and plugged it in and left it for 8 hours but its still not charging
  • 8 more comments
  • Jean Biggs
    Jean Biggs Jan 20, 2008
    Thanks was helpful
  • Anonymous Mar 13, 2008
    Battery will not charge at all.
  • Tys Mom Mar 13, 2008
    Battery will not charge.
  • Anonymous Mar 26, 2008
    and I have that problem.
    new batery was work good 7 weeks and now can't charge it
  • sk8leona Jun 29, 2008
    I also am having problems with the battery taking a charge. Is this a warranty issue? Will buying a new battery fix the problem?
  • Robert Brady
    Robert Brady Jul 10, 2008
    Same problem, and its intermittent sometimes. I can have it running fine for hours/days, then it will start beeping and the charge light is off. I will pull the battery out (while the AC cord is still connected) and its shuts off completely. I have a new battery and its doing the same thing, and I just had the motherboard newly replaced a couple of months ago.
  • cvbeckwith Jul 17, 2008
    I also have a Aspire Acer 3680 with pretty much the same problem. I bought new battery and new ac adapter the machine was intermittently chargeing before it shut down and will not start now? When it was under warranty I sent it to acer to have the problem fixed it worked for a while then started all over again . It is no longer under warranty even though it is the same issue. Any ideas on what is causing this? and a fix??
  • Norman Basham
    Norman Basham Sep 01, 2008
    Battery won't charge, no led charge light on laptop when plugged in, adapter light flashes instead of staying on.
  • zarem Jan 05, 2009
    I have my notebook hooked up to the charger but the charging light doesn't even come on. Was working great, then it would charge off and on and now it's not charging at all.
  • johndelrio Jan 09, 2009
    i have a dell e1505 notebook. will not charge so i replaced the battery and the ac charging cord. still will not charge. what to do?
OGBAMEY
MEN I ALSO HAV THE SAME PROBLEM AND I JUST CANT FIX IT
Posted on Jun 18, 2008
I have the same problem. It wont charge.
Posted on May 01, 2008
    Sergeant:
    Champion:
  • 244 Answers
It could be motherboard problem, since you already try new battery.
Posted on Jan 19, 2008
I have a nextbook 7 or 8 tablet. it no longer charges in any way, and it gets extremely warm when connected to a charger no mattet how short a time it is plugged in for.
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Jun 07, 2014 | Tablets & eReaders
I need to know how to use my new laptop battery correctly.
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
Mar 16, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Sunfire power chair won't charge but lights up when plugged in
you need to have the batteries tested it is possible that if left in a discharged state for an extended time that thee batteries may be damaged and will not be able to be recharged
May 24, 2010 | Pride Mobility Products New Pride Mobility...
My TOSHIBA MINI NB205-n313/9 10.1 inch net book will not turn on
The laptop is not turning on?
Remove the battery and try boot the machine on AC power only. If the computer starts up turn it back off, reinsert the battery and try to boot the computer again.
If it still won't boot with the battery inserted then i suggest you send or take the computer back as there is a hardware problem.
Regards.
Sep 15, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Toshiba Satellite a205 Battery Will Not Charge
You did what all should not have been done. your battery works as a buffer between high surge of electricity which comes through electrical supply i.e. it protects your smps from burning up. From your current position it seems your smps fuse has blown. If they have given one or else your smps itself has gone. I'll tell you for your future usage of battery. Whenever you get any electronic equipment with chargable battery you should never switch it on unless and untill you have charged it for continuous 24 hours. Never try to run such equipment directly through dc or ac power. Hope your fuse has gone its not costly.
Jun 19, 2009 | Toshiba Satellite A205-S4607 Notebook PC
Toshiba laptop power light on but not working
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
Jul 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Th battery power
YOU HAVE TO USE UR USB CABLE TO CHARGE IT *******
Apr 14, 2008 | RCA OPAL M4001 MP3 Player
LG Chocolate
dont listen to the other guy you would not get three batteries wet unless your dumb... it is probably a cracked circuit board in your phone
Mar 10, 2008 | LG KG800 Cellular Phone
Battery life
I know exactly what your talking about, I phoned the company and got the run around, somebody, anybody please help if they can!
Feb 20, 2007 | Pioneer XM2go Inno Satellite Radio...
Computers & Internet Logo
817 people viewed this question
Alun Cox
David Payne
David Payne
