Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Two keys: "minus" and "delete" are not responding Any solution are appreciated
  • 51 Answers
Need to be opened and cleaned, if that failed then you need a new keyboard
Posted on Dec 09, 2009
How do I delete an iphone app that won't stop downloading?
To delete an app, existing or downloading. Hold down the icon until the icons shake and red minus icon appears, then tap on red minus button to delete.
/uploads/images/delete-iphone-app-stop-downloading-35312801-1-1.jpg
Apr 07, 2015 | Apple iPhone 4S
I would appreciate if you could suggest some solution to this problem. I inadvertently pressed the temperature control minus button so the lowee reading went from 35 til ON. I would like to change it...
Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 30 minutes and plug it back in. Turn the Master ON/Off Switch to ON. The controls should have reverted back to the original factory settings. You can now, set the controls as you like.
Hope this helped you solve the problem. Please let me know. Thanks.
May 28, 2011 | LG DH404E Dehumidifier
Help!! The window on my BT Yahoo mail seems to
Try pressing the CTRL and minus key together.
(minus is the one with - on it usually top right next to + key).
also CTRL and + makes it bigger.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Yahoo Mail
Hey, what can I do if on a ceramic hob there is no error message but a letter "L" at each section? The control buttons don't respond I only can switch off and on again but nothing happens. Please...
You've probably accidentally activated the child-lock "L". It would help to know which model you have as the deactivation method can vary on different models. However, this is the process for activation or deactivation on the EKI-848 which looks like the one in the above picture:
Switching off the childproof lock
1. Press the ON key.
2. Then immediately press the Plus key of the cooking zone at the left-back and the Minus key of the cooking zone at the right-back simultaneously.
3. Then press the Minus key in order to deactivate the childproof lock. The "L" will go off.
If this doesn't work or you have a different model, please post back and I will let you know the correct deactivation method for your model.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | Kuppersbusch Glass ceramic induction hob...
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
Create and share toolbar is grayed out
try this
The toolbars can be turned off. They can also be dragged out of the viewable area. If they are turned off, they can be turned on by going to the View menu, to the Toolbars sub-menu and selecting the toolbar that is missing. If it already has a check next to it and it is missing from the program, then it has been dragged out of the viewable area. To correct that:
Warning: Make sure that you are only deleting folder/keys that you are directed to delete in the Registry. Deleting any other folder/keys may cause problems with your system or other programs. Novadevelopment assumes no liability for changes you make in the Registry.
  1. Close the Publisher Pro program.
  2. Go to the Start button and select the Run option.
  3. On the Run window, type “regedit” without the quotes in the Open field.
  4. Click the ON button. This will open your Registry Editor program.
  5. Scroll to the top of the left-hand side of the window to where you can see the My Computer option.
  6. Click the plus sign (+) next to the HKEY_CURRENT_USER folder and this will expand a list below it. If it has a minus sign (-) next to it, skip to the next step.
  7. Click the plus sign (+) next to the Software folder and this will expand a list below it. If it has a minus sign (-) next to it, skip to the next step.
  8. On the list that appears below Software, locate the folder labeled Nova Development. Click the plus sign (+) next to the Nova Development folder. If it has a minus sign (-) next to it, skip to the next step.
  9. On the list that appears below the Nova Development folder, locate the folder labeled Art Explosion Publisher Pro. Click the label for the folder Art Explosion Publisher Pro. It should now be highlighted.
  10. On the Art Explosion Publisher Pro folder name is highlighted, go to the Edit menu and select the Delete option. On the warning box that confirms the delete, select the Yes button.
  11. Close the Registry Editor window.
Jun 06, 2010 | Nova Development Photo Explosion Deluxe...
Minus Key doesn't work. all other keys work fine.
Please define the "-" minus key. Are you talking about the PC's keyboard or a button on the printer's front panel.
Also, what is the make and model of the printer.
Don
Feb 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
Arrow keys do not work in Bios
try the page up and page down keys
Sep 23, 2008 | Dell Latitude D600 Notebook
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
42 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
