Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Bosch gas oven problem
Our oven will not self clean. The first time I tried alarms went off and the display code 43 came on. I waited a few months before trying again (big mistake) same thing happened and the warranty has expired. This time though, the oven lock display is continually blinking. At one point after the second attempt at self-cleaning we got a code: GAS 0600 34 001 200. The oven door does not close completely- probably that is why it won't lock to self clean. Sure hope you can help! Thanks,
Sandy Mewhinney
PS I had to enter a bogus product code since our Bosch wasn't listed.
  • Anonymous Mar 25, 2008
     error code 43 coming on whenever oven is near or over 400 degrees.  continuing problem with no solution yet.
  • 1314 Answers
SOURCE: GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Posted on Feb 14, 2008
  • 1314 Answers
SOURCE: Self-Clean Cycle --- Lock Door Light Flashes
the door lock should be automatic just set everything and push start
Posted on Mar 30, 2008
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Posted on Feb 28, 2010
  • 149 Answers
SOURCE: when i try to set the self cleaning on the door
check for an obstruction in the latch , if the lock cant be set , it will not clean
Posted on Mar 27, 2010
  • 494 Answers
SOURCE: GE profile spectra gas stove displays 'locked
You might try to reset the unit by unplugging it. Plug it back in, reset the clock & try it again. Hope that helps.
Posted on May 17, 2010
Whirlpool gas range self-clean cycle produces FSE1 on display and door doesn't lock, audible alarm sounds
I found this on an appliance forum. It sounds the same as your problem. They say the code is F5 E1. Apparently the door lock latch is stuck.
Appliance Repair Forums
Dec 30, 2014 | Whirlpool Kitchen Ranges
The oven is giving error code LOC
amana self cleaning convection oven displays an F9 code.
Sep 06, 2011 | Maytag Kitchen Ranges
Excessive smoke comes out from oven when cooking
hmmm sounds a bit strange is there anything at the bottom of your oven that has been spilled on it even on the heating coils? (if electric) (if gas there could be a very serious problem with the oven that needs fixing right away!)
Dec 17, 2017 | GE 30" Built-In Single Electric Wall Oven...
Beeps - won't stop - f90 code - thinks door is locked.
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 23, 2009 | Frigidaire FGS365EC Stainless Steel Gas...
GE true temp oven f2
This happens every time I clean my oven. It overheats, shows the f2 light and BEEPS loudly. The only way to stop it is to turn the oven off at the breaker box, wait until it cools (usually 2-3 hours), flip the breaker back on and start the process all over again until the unit is clean. If it's not to dirty, sometimes it's easier to juat use Easy Off.
hope it helped
Jan 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Cleaning the over
Try pressing and holding the cancel button for at least 5 secs. Wait a few mins. Something different should display on the display panel. The door should unlock after a couple of minutes.
Dec 25, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
