Question about Toshiba Televison & Video
Channels keep advanceing with remote - Toshiba Televison & Video
Need codes for ge remote
Posted on Dec 09, 2009
SOURCE:
How do I program certain channels that I want with my universal remote.
During initial set up of your TV, you are prompted to perform a channel search to find all active channels in your area. After that, you can delete channels you don't want. When you turn on your TV and press the CHANNEL UP button, you will be able to advance through the preferred channels. One drawback to this approach is that the next time you perform a channel search you will have to repeat the selection process.
Apr 27, 2016 | Universal Televison & Video
Front panel buttons and remote have stopped working.
Is the favorite channel menu a function that is normally accessed by a button on the remote?
If so, that button on the remote might be stuck.
If this is the case, the menu may at times pop up all by itself and other buttons on the remote and on the TV's front panel may not respond at all (it had happened on my remotes more than once).
Try to clean the remote control (the housing, rubber pad with knobs, circuit board) with ethyl alcohol, when you clean the housing, you should also clean the holes through which the buttons protrude, there might be some dirt that keeps the button stuck.
It may also be a stuck button on the TV front panel, so check these too.
Also, it could be something else, i just wrote the description of a problem and the solution which to me seemed most likely.
Hope you get it fixed.
regards
3rq8 (Triarcuate)
Jul 25, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
1000 remote my hard keys keep doubble clicking my tv
The best bet is to update the firmware on your remote and if you are using an RF extender, update it's firmware while you are at it. Once you update the firmware for both, then update the remote.
Thanks,
81
Dec 11, 2008 | Logitech Harmony 1000 LCD Touchscreen...
Channel keeps skipping on rca t.v
Problem with channel skipping has rectified itself. I simply unplugged the set and and started over with remote intructions on signal and channel setting. The tv was also turning itself off and on, this also has ceased. Thanks, hope I don't need you later.
Nov 24, 2008 | RCA Universal Remote Control
Remote only advances by one channel.
The button on the remote next to 0 and below 9 has to be depressed to _ _ before you select any 2 digit channels. I had the same problem and accidently figured it out. Hope it helps. TC
Jul 13, 2008 | Memorex MT2206 TV
Can't advance channels with remote
UNPLUG cable settop box and reset...Then go from there. Let me know and good luck.. GURU JAY
Feb 05, 2008 | Televison & Video
INPUTING CHANNELL ON REMOTE
using the meniu of tv select fine tuninig end memoreyschen
Apr 20, 2007 | Wanlida Group LTD-1510 15 in. TV/DVD Combo
Televison & Video Logo
24 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
