Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
My I/O Magic 320GB GIGABANK Drive has stopped working. One day I took the power cord out so I could setup my cables again and then when I plugged it in it would not turn on. I then bought a new power cord and it's on now..but now the drive isnt recongnized or anything... HELP! P.S How do I take the enclosure apart so I can put this inside my PC?
dodgecharger
  • 254 Answers
SOURCE: My Gigabank will not read on my computer anymore
We are seeing alot of posts reporting problems with these USB connected portable drives. Maybe this is one of those ideas that sounded good, but results in lots of headaches, lost data. First, try the drive on another machine- see if works there. In Control panel, select Administrative Tools, Computer Management, Disk Management... Does the drive appear there? It is possible the drive needs repartitioned/reformatted (not good for your data). You could take the USB drive case apart, check the interface cabling to the drive, and try it again. If it still doesn't work, try removing the drive and installing it in a desktop computer as a slave drive. I've only had one of these USB connected drive assemblies apart, but that one used a drive with a standard 40 position ribbon cable interface, the same as what is used on pre-SATA desktop systems. If you've gone this far, you could try removing the drive from the case, and installing it in a desktop machine as a slave drive, and seeing if you can get anything off it there. Diagnostic software from the manufacturer could also be run here too. None of this may get your project back however, unfortunately. For those highly important things, a backup is really suggested- and you know why- the hard way.
Posted on Oct 02, 2007
latinmcgyver
  • 208 Answers
SOURCE: Problems with Magic GigaBank 12 GB USB 2.0 Hard Drive?
sounds like bad usb data channels on the drive the far left and far right are powers if im correct the 2 centers are data - and +
(i burned a usb memory stick once with a wrongly wired front usb plug)
Posted on Aug 03, 2008
SOURCE: iomagic gigabank 250 will not show up on pc
Let me add acouple things to Lolita's solution: This worked on a I/O Magic Gigabank 320. If the initialize wizard does not appear. Go to the left side of the window that should have popped up listing all of your drives. Right-click on top of the drive you are adding. There should be a red circle with a minus sign on it. Right-click there and select initialize. Now the initialize wizard should start. The drive gets hot. I'd keep it off and only start it when needed. This may make it last longer and help with power surges as well.
Posted on Sep 24, 2008
SOURCE: I/O Magic external drive not showing up in computer
Had the same problem with the 120GM IOMagic. I removed the drive from the case, detached the circuit board leaving just the Hard drive and hooked it up to a cable I bought that allows you to read any hard drive through the USB post. Was able to retrieve all the data on the disk. The problem was the iomagic interface board.
Posted on Feb 08, 2009
SOURCE: My PC Will Not Recognize My External Hard Drive ...
Here are a few solutions.
1. If it was working and it doesn't seem to be any longer. Check to see if your PC supports SATA drives, if so you might be able to have the hard drive removed and install or temp install in the PC itself to get the data off.
2. If it has never been recognized then try this.
Remove the Hard Drive fom the case. Check the drive jumper settings. If they are on Cable Select change them to Drive 1 (slave) it should show proper jumper settings on the drive itself. Put it back together and give it a shot. It should work.
To take it apart. The silver on the back that tells you what each port and switch is is a sticker. Remove this. You will then find 2 screws. Remove the screws, but be careful. The front cover should slide out of the casing with the rest of the insides. The drive is then held in with 2 screws on each side. Remove these and disconnect the 2 cables attached to the drive.
When done reverse what you did to put it back together.
Posted on Feb 12, 2009
Need power cord
Try this OMagic Cables (bottom left CP1205) You may need to write (email) to them re European distributor/retailer
Feb 12, 2014 | IO Magic Corporation GigaBank (I250HD35)...
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Hard drive flashing
There is a certain amount of very voltage sensitive circuitry in the enclosure and it was damages by over voltage. Your best bet is to replace the enclosure. These are available from China on eBay for around $18. Much less than to have your enclosure repaired.
Mar 22, 2010 | IO Magic Corporation GigaBank (I250HD35)...
GigaBank 250 GB USB 2.0 External hard Drive - How to open case ?
Remove the cover plate from behind the drive (where the plugs and on/off switch are.) You have to then remove the 2 screws. After that pull on the end with the blue lights to slide the hard drive out. If you have a tower computer, you can permanently install the hard drive and it should work fine as a secondary drive. Just make sure the jumper pins are set to "slave".
Mar 29, 2009 | IO Magic Corporation GigaBank (I250HD35)...
I can't remove the HD from the case
It took me a bit to figure it out, so here it is.
1. Pry off the aluminum plate from the back side. Its held on with a rubber cement like glue. Use a thin blade to get under the plate and work it around the perimeter and it will lift off easily.
2. Remove the two screws that are now exposed. The back cover or "end plug" can be pulled off now.
3. Grab the front "plug"and pull and the drive tray will slide out. The Drive is attached with 4 screws to the tray. With the drive screws removed, the drive can be rocked out gently ..lifting the front of the drive up and out of the tray. Now you can get access to the power and data cables so that they can be unplugged. The drive is now free.
I have 2 of these drives and both have poor power connections at the drive enclosure back connector. One finally failed completly, so I removed the drive form the I/O Magic enclosure and directly connected it to an IDE port in my desktop. The hard drive worked perfectly,so I was able to get my data recovered. I plan to cut off the power cord connector and directly wire it to the enclosure, to eliminate the bad connector design.
I bet most all the trouble that people are having with this series external drive is caused by the bad power connection.
Hope this has helped.
Mar 13, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Can not open Gigabank 8gb in windows xp
Read this article but only the Response section from
the site-reader:
http://www.hackphoto.com/2006/01/21/io-magic-gigabank-8gb/
Wow, you have purchased a "magical" device
that judging from the response from other owners like
you, its a disappointing investment :)
When you decide to crack it open and take the CompactFlash card to your card reader, you should aware
that you will suffer greater risks of damaging it, okay?
I have warned you :)
Dec 26, 2008 | IO Magic Corporation GigaBank 8.0...
Hard drive shuts off after 10 seconds
There are a variety of things that can malfunction on your external hard drive:
1) The cable
2) The external hard drive casing
3)  The hard drive itself
If you have tried plugging in your hard drive to different computers and are still having the same issue, then there is either a problem with your casing or with the hard drive itself, because you've already switched out cables.
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computerstore, and also available by going to our website at www.iomagic.com and clicking on Drive Enclosure.  Make sure to get the right size enclosure.  The GigaBank 320 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within your warranty period.
For specific warranty and replacement information, go to www.iomagic.com  and click on Support.
Have a nice day,
I/O Magic Technical Support
Sep 08, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Drive not being recognized; blue logo blinking
I have an I/O Magic 320GB drive. It's easily taken apart by gently removing the silver-colored aluminum sticky plate (by the power switch, USB, etc). Then you remove the two screws and remove the black plate. After that you can push out the entire drive harness and remove the screws and connectors to take the hard drive out. It's easily swapped for a different HDD, and the drive is easily placed as an IDE internal drive. If you hook it directly to your computer you can run diagnostics on it and perhaps data recovery software like "Recuva". Most external drives are pre-formatted as FAT32, single partitions but can be reformatted to any other format.
Oct 28, 2007 | IO Magic Corporation GigaBank (I250HD35)...
Sep 28, 2007 | IO Magic Corporation GigaBank 8.0...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
314 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Paras Waiba
Level 1 Expert
M_Butkus
Mohamed Ismail
Mohamed Ismail
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
