Question about Brother HL 5140 Laser Printer
Our Brother HL-5140 is not printing. It doesn't
Our Brother HL-5140 is not printing. It doesn't pull any paper through to be printed although every once in a while it will act as if it's going to print and just doesn't "grab" the paper. This leads me to believe it may be a spooling problem.
    Problem Solver:
  • 4 Answers
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Posted on Feb 02, 2010
How do you get a page count from an HL 5140/
On the HL-5140, you can print out a config page which will show the page count on it by pressing down the Go button (the blue button). Hold it for a few seconds, until the config page starts to print out.
To find configuration page instructions and page count tips for other printers, copiers, and fax machines, check out How to Print Configuration Pages.
Aug 22, 2011 | Brother HL 5140 Laser Printer
My Brother HL-5740 Is jamming after every print jog. It's pulling two sheets through, the first sheet with the print job and the second sheet clear, Its like every job has two sheets. The second sheet...
You probably need to clean the paper pickup roller above the paper tray. A clean cloth dipped in diluted kitchen detergent and a couple of drops of alcohol, will clean the rubber rollers. Stroke the cleaning cloth firmly from side to side all the way around all the rollers. Also clean the paper separation shoe (rubber pad) at the front of the paper tray. The last thing is to make sure your paper is dry. Damp paper sticks together
Oct 16, 2017 | Brother HL 5140 Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
HL-5140 model. the paper light is flashing and
Hi Patricia,
Try to do a factory reset on the server.
Whilst the printer is turned off, press and hold the GO button as you plug the printer on to the socket. Notice that all lights on the printer will turn on as well. Continue pressing the go button until the light for the toner goes up and once its up, release the button. Next, hold down the Go button again until the "Yellow Status" light turns on once on, release the Go button. Wait for the printer to initialize and see if the error went away.
Hope this helps.
Jan 05, 2010 | Brother HL 5140 Laser Printer
Brother Laser Printer, paper gets stuck and printing wipes off.
Opened up the back and found there is a plastic cog wheel on the end of an orange drum, which must be the Fuser Unit, which was damaged. So the paper was getting as far as the drum but the rollers to pull it through the Fuser Unit were not going round. A new Fuser Unit seems to be about £99 plus VAT and I don't supose a new printer is much more than that. So if anyone has a spare Fuser Unit for a Brother HL 5140 which is still in good working order I would be happy to consider buying it. Alternatively I have 2 x spare drums DR3000 and 1 x toner TN3060 for sale !!
Oct 25, 2009 | Brother HL 1440 Laser Printer
Ghosting on prints
Wrong paper type can cause this, also if it is damp or too thick. Also check that you have the correct type of paper (thickness) selected in the driver. Ghosting can also be caused by a faulty drum unit, since you just replaced it maybe there is warranty left on it?.
May 24, 2009 | Brother HL 5140 Laser Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Feb 21, 2009 | Brother HL 5140 Laser Printer
Will not Print online Coupos
Just fixed my Brother HL-5140. Hope this helps :) I have struggled for years and finally figured this out from the Brother website.
If you are unable to print coupons from the Internet the print processor
setting in the driver needs to be changed. To change the setting,
1. Open Printers and Faxes.
2. Right mouse click on the Brother printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Try printing the coupons again.
Aug 20, 2008 | Brother HL 5140 Laser Printer
Brother HL-5140 printer
make sure you have the drum seated all the way in, then unplug the printer and plug it back in.
Feb 20, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
274 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
