I have bought a USB2.0 hard drive from PC world and when connecting it to my P.C. the usb chanel just bleaps. can you help?
  • 3,153 Answers
Beeping usually meant that windows has found the drive. Open windows explorer with the drive disconnected. whilst watching the screen connect the drive and it should appear there as an extra drive.
Sometime you may have to format them but you should check first in case it is already done and has any software that the manufacturer may have placed on there.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you don't do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to check the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safely Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Dec 09, 2009
    Guru:
  • 1,481 Answers
Pls explain ur problem in detail,
did the HD that u bought came along with a CD
if so u may have to install the driver in that CD for the HD to be recognized by the PC
else try connecting it to another PC and c if it works there.
u may have make some changes to the Device manager setting....will tell u in detail how to do that once u explain ur problem in detail
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Can i connect a usb hard drive to a 3com 3CRWDR101A-75
It appears that this router is suitable for network hard drive not USB hard drive. Currently most hard drives available in the market are network compatible.
Feb 11, 2012 | Computers & Internet
Windows 7 driver for160GB eGo USB 2.0 Portable Hard Drive?
According to the Iomega Support web site you do not need additional drivers for using your Iomega eGo drive with Windows 7 unless you have a USB 3.0 device.
See this Iomega document on what you should do if your drive is not detected on Windows 7
Jan 14, 2012 | Iomega 33914 Storage 160gb Ego Silver...
When i plug in my hard drive it starts to make a clicking sound as the motor begins. It is not connecting. What do i do?
This doesnt always means the drive is bad, it can just be the cable...
My girlfriend bought me a verbatim 250gig external drive, which accoring to her was new from the shop but my PC couldnt pick it up, when connected, blue light flashes with a clicking nose... tried all usb ports but nothing... (wanted to take it back but she lost the receipt!!!!) after that didnt really bother with it until one evening playing FIFA on my sisters playstation and realised that the usb cable is the same as my external drive, so tried the cable and VOILA!!!!!!! PC picks it up and works as suppose to, till this day... So guys and gals, before going out to replace your external drive, borrow a playstation usb cable from your neighbor and have a go...
hope this helps
cheers!
Mar 16, 2010 | Western Digital Passport WDXML800UE...
I have one of these harddrives, and bought a new computer. I now want to use it as an external Hard Drive, but do not know how to. Since I bought a macbook pro, this might be hard. It would be best to just...
The best option would be to purchase an external enclosure for your hard drive. Once inserted and connected to the enclosure you will be able to connect your hard drive to your pc/mac via a usb cable.
Hope this helps!!
Please rate!!!
Jan 03, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Can PC hard drive cable be converted to a USB cable?
Try USB2 to ISDE & SATA cable adapter
OR
why not put that 1 st drive into the other computer if compatible.. BIOS should auto detect if it's connected to 2ndry chanel
Oct 27, 2009 | Gateway Computers & Internet
External hard drive not recognized
You need to first narrow down the problem to either your PC or the external hard drive. Do you have access to any other PCs you could try connecting your hard drive to? (think friends, family, public PCs, etc)
If the hard drive works on other PCs, we know it isn't a problem with the hard drive.
If it turns out that the hard drive is fine and the PC is the problem, I would suggest going in to Device Manager and uninstalling everything USB related. Once you have done this, either reboot your PC or right-click inside device manager and "scan for new hardware". All of your USB related devices should reload their drivers automatically. You may want to try this both with and without the usb drive connected.
Another tip would be to try various USB ports.
Mar 19, 2009 | Western Digital 500GB My Book World...
I can not link up with My Book World Edition 500GB
That is because the MyBook is set with a default IP address of 192.168.1.257. You will have to put a static IP address in that subnet range in order to be able to see the external drive. Hope this helps....
Dec 13, 2008 | Western Digital 500GB My Book World...
New hard drive does not recognize usb
Does it make any sounds? Is it spinning up at all?
Try to remove the drive from the enclosure and connect it directly to your PC.
Here's a page with typical symptoms these drives have: http://datacent.com/datarecovery/hdd/western_digital/WD1600AAJB
Oct 31, 2008 | Western Digital 500GB My Book World...
Hard drive not being recognized
my book world is a network drive, you should connect it to a router / switch using an ethernet cable. if you use a usb cable to get it recognized on your computer it will never work
Aug 24, 2008 | Western Digital 500GB My Book World...
69 people viewed this question
k24674
Marvin
Marvin
