Question about Kenmore Elite 45986 Front Load Washer
I oversuds it, get a SUD message, seems like it won't pump water even at the drain/spin cycle
  • 5,911 Answers
You may have an obstruction somewhere in the drainage system. Usually this means the drain pump is clogged. The following link explains how to access and check the drain pump on a Kenmore Elite:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
You may also have to remove the hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Small items (such as socks) can get lodged in this area and prevent the drain pump from functioning.
If anything gets lodged in the drain pump impeller for any significant period of time, it can cause irreparable damage to the pump. Since the pump is supposed to pump at a required volume to complete the drain cycle within 8 minutes, it can start causing error codes to appear if it is pumping too slow or not at all. Some of the error codes that may occur are "F02", "F21" or "SUD". If this is the case, you may have to replace the drain pump. The following link explains how:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
Replacements can be purchased on line at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. Hopefully you won't require a new pump.
If you have any questions about this repair, please let me know. I hope this helps you.
Posted on Dec 09, 2009
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Maytag 3000 washer has error message SUD. What is this and how do I fix it. It occurs in the spin cycle every time I wash. I am using Tide HE detergent. It even does it when I use Zero detergent.
The SUD message usually indicates that the sensor detected excess suds and shut down the washer until the suds subsided. To my knowledge, Zero isn't an HE approved detergent so the amount you use has to be really tiny to avoid the SUD error.
With the Tide HE, you still may be using too much detergent. However, you should check the drain pump and outlet hoses. Sometimes a slow or blocked drain can trigger the error. There is often a filter at the drain to keep foreign objects that were left in the clothes from damaging the pump. Make sure that nothing is in this "coin trap". Have a bucket ready when you take apart the drain to catch the water left in the washer. The pump is accessed through the back panel. (Some front-loaders actually have an access panel so you don't have to remove the entire back.)
If you see excessive suds during the wash cycle, run the washer through a complete cycle while it's empty without using any detergent. This often will rinse out any detergent that may have been left from previous loads.
I hope this helps.
Jul 20, 2012 | Maytag Neptune Washing Machines
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Final spin cycle I get sud error code or f2, water mostly drained but no spin. When I restart the spin cycle just starts to spin then stops, sounds like it drains some more water then makes a small...
Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Get error SUD and will not finish cycle
The Motor Control Unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential Suds Lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Possible Causes / Procedure
• If too much detergent was used:
- Run the unit through a Rinse/Spin cycle.
- Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Sep 30, 2009 | Kenmore HE2 Plus Front Load Washer
F02/Sud error message fabric softner will not dispense
The pressure switch is sensing that there is still water in the unit,it sits at the top of machine under the top cover,it is round and usually red in color remove the hose/tube from it and blow through it to make sure it is clear,you can also remove the switch itself and lightly blow into it you will hear a couple of clicks put it back together and give it a shot..
Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WONT RUN COMPLETE CYCLE WITHOUT F-2 OR SUD
sounds like you have a clogged/bead pump. removethe lower acess panel and from there youll see the pmp clean put remove thescrewout, and clearthe debris. BE WARNED THER WILL BE WATER BEHIND grab a towell or 2
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer
"F02" and/or "Sud" error are directly related to a common problem in this case. You have something clogging your drain line and/or drain pump. The error will not go away until you clear the problem. The following links explain how:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In some cases, the drain pump may require replacment. If something has been lodged in the pump reservoir for any period of time, sometimes the pump impeller can become damaged to the point where it does not pump water. Replacment pumps can be found at searspartsdirect.com or repairclinic.com. Just type in your model number inthe search menu. I hope this helps you resolve your problem and that you do not require parts. Let me know if you require additional assistance.
Jul 18, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Miele
Clean the drain by opening the door on the bottum left.
Use the yellow plastic thingy in the front of the soap drawer to do it.
You can open the machine door by pulling the yellow tag in the bottom door.
Drain the water through the filter, clean the filter and close.
Then unplug the machine and tilt it forward by about 1 foot until you see water coming out of the bottom (put towel on floor).
Plug back in and voila!
I do think that this machine is a major pain. No spin cycle and this kind of stuff to go through. Anyone want to buy mine?
Dec 24, 2007 | Miele Touchtronic W1213 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
170 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
