Question about Sony DAV-S500 System
No power to player!?
I have a dav-s550. All of a sudden it will not turn on, no stand-by or anything it's just dead!! PSU? I'm pretty handy at repairing PC's but have no experience with DVD players, so any help would be much appreciated!
Thanks
  • fredwww Jun 28, 2008
    i have a same problem. i checked main fuse and it's ok. what's a next cheking?
My DAV_S500 has just developed the same problem, it was playing a DVD picture flickered a couple of times then the whole thing just died ! no power to anything ? removed cover to check foe internal fuse, found on on the combined power board but its ok ? suspect its the power board but having no luck finding a replacement ? suspect part no is 1-682-284-42 but not sure ... can anyone help ?
Posted on Oct 03, 2008
Open it up and check the main fuse. It is located on the board where the wall plug enters the chassis.
Posted on Feb 24, 2008
Sony DAV-C700 DVD player not working
is there any display in the LCD screen of your player??
Jun 28, 2008 | Sony DAV-C700 System
Sony dav s550 dvd has no colour
Hello, welcome to Fixya!
The display setting is set to NTSC either on the TV or DVD that's why it is showing in black and white.
Check the DVD display settings and change it to Pal or auto, save and try again. Also, check the PAl settings on the TV.
If the above doesn't solve the problem,then it means there is an incompatibilty problem between the TV and DVD.
I hope the above is clear.
Re
Dec 14, 2011 | Audio Players & Recorders
Dav-dx250 volume is very low with maximum volume
How does it sound when you calibrate the speakers (page 75)? THAT is how the basic hardware is verified. Anything that doesn't work after that is usually a setup or source issue. Read the manual.
http://www.retrevo.com/support/Sony-DAV-DX250-Home-Theater-Systems-manual/id/750dj491/t/2/
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Aug 18, 2011 | Sony DAV-DX250 System
Sony DAV-S400 PSU C916 value? Note that you found the answer & there are 3 values dependant country. What is value for UK model?
Service manual does not have schematics or part list for PSU board of DAV-S400, however, it does have part number of complete power supply board that I can provide you if that helps.
Thanks.
May 24, 2011 | Audio Players & Recorders
SOnt DAV S550
There is a gear underneath the tray that may be broken or possibly the open close detect switch nay be bad. You will have to remove the tray,you will then see that gear.
Aug 10, 2008 | Sony DAV-C770 System
Dead Kiss DP-1500 Player
The problem is a well known weakness of all Kiss DP 15xx and DP/VR558 players.
The PSU (power supply unit) can't stand the heat and will fail typically after 1-3 years of operation/stand-by. At first the voltage falls fading the light intensity of the front panel, then odd malfunctions occur, and finally the unit ceases to work.
I own own of each, and they are close to identical as to the PSU and both have had the same problem.
The condensators of the PSU are of a inferior brand and typically 3 or more of them will "burn" leaving a bulge at the top end of the cylindrical component or alternatively leak a dark brown resin-like substance onto the print board.
A complete set of new condensators can be had for approx 5 euros and at that price leaving some of the original condensators unchanged seems unwise.
Read all about the fix at: http://www.mpcclub.com/wiki/index.php/Psu
Be advised that opening the cabinet voids any warranty, but as Linksys the new owner of the Kiss brand refuses to repair- or pay for repairs this is of little concern.
Jun 10, 2008 | Kiss Technology DP-1500 DVD Player
Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Mar 27, 2008 | Sony DAV-S500 System
the fuses are the first obvious suggestions.
in the main AC plug, and if theres any sign of fuses on the Circuit board itself.
If it,s over 2 years old, i,d think about getting a replacement.
as repairs nowadays cost an arm and a leg, and only usually warranted between 30-90 days.
If it,s done it,s job. then it,s time to think about a replacement.
Mike @ Compurepair.
Feb 22, 2008 | Sony DAV-DX150 System
Disc sticking
Lasers are mechanical and focusing parts. Over time, mechanical parts can wear out and focusing parts lose focus.
Try a wet/dry laser cleaner using alchol based cleaner. If this doesn't work, connect a cheap DVD player to it so the Sony system can provide audio....
Jan 01, 2008 | Sony DAV-S500 System
Sony DAV-S500 System Logo
336 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
