Question about Brother DCP-585cw All-in-One Wireless Color Inkjet Printer
My Brother DCP-585Cw is showing a message 'Unable to Print 36'. What should I do?
SOURCE:
  • 215 Answers
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
  • 34 Answers
SOURCE: print unable 36
check the print catridge inside make sure it`s inserted properly
Posted on Apr 13, 2009
  • 904 Answers
SOURCE: Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
Posted on Jun 04, 2010
Davethesnake
  • 689 Answers
SOURCE: unable to print 50
simple driver configuration problem linux is (the Cups printing system) is pretty universal just get your settings right or even cr even surrogate settings it should work
Posted on Sep 06, 2010
SOURCE: my printer brother DCP -
You can see someting at Cardtridge.
Posted on Apr 20, 2011
Unable to print 36
Possible Reason:
1. High voltage power supply PCB
failure
---Replace the high voltage power supply
PCB ASSY.
2. Harness connection failure of high
---Check the harness connection of the high
voltage power supply PCB and reconnect
it.
3. Main PCB failure
---Replace the main PCB ASSY.
Aug 08, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Brother DCP 585CW unable to print error 46
A possible reset might solve hence remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Mar 21, 2011 | Brother DCP-585cw All-in-One Wireless...
I have DCP-585CW and get the following error message "Unable to print 70". Would you let me know how i may clear this problem? Thank you, Farzam
Unplug the Printer from the wall and PC, now reboot PC, when at desktop next, plug in the printer to the wall, and turn ON, now after a bit, you should be able to go to printers and find your printer, or right click on the printers icon, choose properties, & open, now print a test page to see if you have connectivity too. make sure you driver is installed too. This link below, will show toy step by step, in detail how to do it all. http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/dsn/en/document?c=ae&l=en&s=gen&docid=B1C81A9461454AFF9F20F5305385C6CA&journalid=87F86FEAA411F5EDE040AC0A64E9621D&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=
Jun 07, 2010 | Brother DCP-585cw All-in-One Wireless...
My brother DCP-585cw printer prints too slow. What can I do to speed it up?
Go to the control panel and then into the printers section. Right click the DCp-585cw and select printing preferences. Under the section quality chose fast. This should speed things up.
Mar 31, 2010 | Brother DCP-585cw All-in-One Wireless...
Brother DCP-585cw All-in-One Wireless Color Inkjet Printer Logo
137 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
