Question about Northern Industrial Tools Electric Meat Saw/Grinder
Can't get the blade to stay on track - Northern Industrial Tools Electric Meat Saw/Grinder
    Sniper:
  • 61 Answers
There is an adjustment you can make to the top guide wheel to make the blade stay on track. There is a screw with a lock nut just beneath the main bearing for the top wheel that is used to "tilt" that wheel to allow the blade to stay where it is suppose to. This needs adjustment periodically due to normal wear in the bearings or maybe due to a blade which is made a little different than the last one that was on there. Loosen the lock nut, then turn the adjusting screw to tilt the wheel in the direction needed to keep the blade on. Not much adjustment is usually needed. After turning the screw, jog the motor on briefly (with the blade on) and check how it runs. Keep adjusting until you get it running true. Lock the nut and you should be good.
Good Luck. Be Careful while jogging the motor to check the runout, as you will need to do this with the guards out of place.
Posted on Dec 10, 2009
How to adjust the blade on skil bandsaw 3385 that will not stay on
This is one of most common problems with Skil saws. Make sure that you set the correct tension and track the blade properly. It could also be problem on the blade specially on the weld. I suggest you visit bandsawblog.com for helpful band saw techniques and sawblade.com . I get my blades from them.
Sep 18, 2014 | Saws
How do I adjust the blade to stay on?
Many times this is caused by worn beearings or a worn rubber "tire" on the idler or drive wheel.
Aug 13, 2014 | Saws
I have a ****** 16 bandsaw that the blade doesn't track properly
Make sure you properly installed and tensioned the blade . You may want to read this blog : http://bandsawblog.com/band-saw-tracking-procedures/ . Hope that will help you.
Jan 17, 2013 | Saws
Why won't the blade stay on the wheels of my
You need to adjust the tracking, at the very least. Get a user's manual and it will describe the procedure to adjust the wheels to keep the blade tracking properly. If it's a used saw, it's possible the previous owner didn't maintain it properly and you'll have to replace the rubber, or even a wheel (possible but very unlikely).
Jul 13, 2011 | Saws
Saw blade jumpes off at motor pulley on horizontal band saw
It is probably not tracking. you need to back off the guides, get the blade to track in the center of the tire by hand. Then torque it up a bit till it twangs, Then pull the guides up the blade and just touch it, don't push it at all, the bearings too. This should track and not jump off. If it does, then one of your wheels is out of whack, check them with a straight edge with the blade set. See if they are in line. One of the bearings could be bad. Check it out.
Apr 15, 2010 | Wilton 5" X 8" Dry Horizontal Bandsaw Band...
Blade stays in a bind. coming thru the table it is not straight coimg down, it is set to zero on the tilt gauge, which puts the blade hitting the little angled guides above and below the table
Back off all the adjustment to the guide bearings and the guides. Get the blade to track, and stay in the center of the tires,(wheels), tighten up the pulley, then set the top bearing to the blade, just touch it, then the bottom, turning the blade by hand, then bring in the guides just to the back of the teeth. The guides should be close to the blade but not touching it.You should be all set, If the blade won't track by itself, you have an alignment problem with the two wheels, if it is a 3 wheeler, then one of them is off. Check them with a straight edge against each other,if you can, one will be tilted. It might need a new bearing it self.
Feb 15, 2010 | Craftsman 3/8 x 80" Band Saw Blade, 6 tpi
Top tire comes out from under blade, blade stays in place. Have replaced blade and the proble still happens but off the other side of the wheel
Glue tire onto wheel. Make sure that blade is tracking well by seating itself back in the gauge blocks almost against thrust bearing by adjusting lateral knob
Jan 22, 2010 | Saws
New blade will not stay on top belt
There should be adjustments for tracking the upper wheel. Turn the machine by hand until the tracking is perfect. Check the bearings in both wheels for looseness. Hope this helps!
Jan 21, 2010 | Saws
Northern Industrial Tools Electric Meat Saw/Grinder Logo
303 people viewed this question
Top Northern Industrial Tools Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Northern Industrial Tools Kitchen Appliances - Other Expert? Answer questions, earn points and help others
