Question about Trademark Poker Keystone Diecast Electric Train Set
How do you make the train smoke? Which hole receives the liquid?
  • 567 Answers
Not too sure if its like one i had many years ago you put some three in one oil in the funnel
Posted on May 23, 2010
SOURCE:
How do you fix liquid locked in a homelite mp88 chop saw
EXTREME Caution should be used. A FIRE can result if this is done improperly !
1) Remove spark plug, ground the plug wire if possible
2) Make sure ignition is in the OFF position
3) NO choke
4) Wide open throttle
5) Shop rag over spark plug hole
6) Pull until no liquid comes out of plug hole
7) Re-install spark plug
8) Continue to pull recoil with throttle open, NO choke
9) Engine will start slowly with huge amounts of smoke, run until the smoking stops.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Feb 15, 2017 | Homelite Garden
Unit will not smoke, this is the second time I ran train.
have you added the correct amount of smoke oil to engine ?
part number 6-37841 lionel
Dec 29, 2015 | Lionel 31960 The Polar Express O Gauge...
The smoke unit stopped working. been run only 5 minutes
??? not sure why a evolution would have a smoke unit in it , but anyways its possible that trains were shipped with only a small amount of smoke fluid in them (makes shipping less messy) a bottle of smoke fluid and a few drops of this wonderful stuff is all you should need to get your engine smoking again
Aug 27, 2015 | Lionel Canadian Pacific Es44ac Evolution...
White smoke on start up
Bernie, keep a check on your antifreeze level in you radiator, if the white smoke smells sweet its probrably antifreeze meaning you have a hole in your head gasket. or maybe a cracked head, Sometimes if a pressure check has been done on your radiator it will put too much pressure on a worn head gasket and create a pin hole. Usually this smoke will occur at first start up or after the car has sit for a while after running allowing antifreeze to leak into a cylinder and upon cranking the engine you will have the liquid burn off creating a white sweet smoke. As the gasket gets worse the smoke will get worse until it smokes all the time. Hope this helps. Also if the vehicle has ran hot lately it can cause a head gasket to blow. Keep me informed if I can help.
Jan 05, 2012 | Cars & Trucks
My 2002 chevy 6.6 duramax has white smoke coming out the tail pipe. What is possible problem?
Sounds like you have eather a small hole in head gasket. or a crack in head. White smoke mean's water in exauest.Try a bottle of liquid glass stop leak first if not to bad . this works good. if not to big of hole. good luck to you.If need any further help just let me know.
Mar 28, 2011 | Chevrolet 2500 Cars & Trucks
Polar Express locomotive will not smoke with smoke fluid in stack and smoke switch on.
You may have to check if there is power to the heating element. You can also check to see if there is too much fluid. You can also put the engine in neutral and tap the chimney hole a few time to kind of "prime" the smoke unit.
Mar 16, 2011 | Lionel Polar Express Train Set
Trademark Poker Keystone Diecast Electric Train Set Logo
350 people viewed this question
Top Trademark Poker Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
thinksewfast
ray gallant
ray gallant
Are you a Trademark Poker Craft and Hobby Expert? Answer questions, earn points and help others
