Turn unit on MFC 210C and it says unable to initate...nothing happens...fax light is on...says look at troubleshooting and routine maintainance
  • ked2016 Dec 09, 2009
    disconnected, then connected holding menu set down...all 4 lights flashing..and has machine error 4F...can'tt get *2864 in...now what?
    did anyone receive my answer when ii tried the ides previous
  • 19,396 Answers
Hi.
You can try first disconnecting power cord for two minutes and check if this is clearing the error.
If that does not work, next step will be entering in maintainance mode, and this should be done by a technician.
I suggest at this point calling Brother at the number listed on the owners manual, but if you want to proceed I will post instructions below:
To display or check error code: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
To enter in maintenance mode:
On FAX models with numerical keypads: Press the following sequence: Menu/Set, *, 2, 8, 6 and 4 keys within two seconds.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press 8 and then 0 keys to recall the machine's log information list (function code 80).
3) Press Start key several times to scroll down through the log menu until you reach the reset command
4) perform a reset.
Posted on Dec 09, 2009
  • Ginko
    Ginko Dec 09, 2009
    You can get rid of the error resetting the purge count. Brother suggests to call service.
    Do the following , I quote from Fixyourownprinter:
    "Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
    This will reset the purge count value. Then the printer will restart"
I have got the error message " unable to clean , see troubleshooting and routine maintainance in user's guide" . I have tried all ways in the user's guide and also other suggestions. Please gi
If your your printer cannot clean automatically, your printer head is probably clogged so badly that you will have to do it manually.... your manual should tell you how to remove it...
Jan 12, 2013 | Brother MFC-210C All-In-One Printer
See Troubleshooting and routing maintenance chapter in User's Guide Init Unable 46
Init Unable 73
Jan 23, 2011 | Brother MFC 210C All-In-One InkJet Printer
Already purged mfc-210c but the same error
não entendo ingles não poderia mada mensagem em portugues
Jan 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C with error code 4F
This will reset the purge count value. Then restart your printer and it should work just fine !
Jan 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
[HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
BROTHER MFC210-C "UNABLE TO INIT"
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
Dec 07, 2017 | Brother MFC 210C All-In-One InkJet Printer
Not printing
hi i have similar problem .error code 5a .can you help ?
Oct 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-210c
You can download the manual from this link: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf See page 11-4
Aug 05, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C
hi this a fateful malfunction only a technician can fix this good luck
Apr 06, 2006 | Brother MFC 210C All-In-One InkJet Printer
23 people viewed this question
k24674
jasbo
jasbo
