Question about Car Audio & Video
Hey in my 1998 honda accord ineed the code to unlock the radio i got the serial number of the radio but one of thr numbers or letter is missing cn u assist me
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Try going to a honds dealership and see if they can help you.
Posted on Dec 09, 2009
SOURCE:
I need 1998 honda accord radio unlock code
Go to a Honda dealer's parts department.
They can get it using the VIN # on the vehicle.
They usually won't do it over the phone, but, you never can tell.
Some may want to charge you to remove the radio to get
the serial number off the radio. If they do, find another dealer.
Dec 14, 2010 | 1998 Honda Accord
Get radio cde for honda accord
Press and hold numbers 1 & 6. This should give you some codes. Take these codes, the VIN and proof of ownership to your local dealership parts department. They can get the unlock code from Honda. If the radio will not give you codes, you will need the radio serial number. This can, usually, be found in the glove box, if not the radio will have to be pulled.
Sep 03, 2010 | 1998 Honda Accord
Need the radio code for my 1996 honda accord special edition
if you dont have your radio code then we need to get your serial number, there 3 ways to get it.
* First try looking in your glove box for a sticker which will be a 7 or 8 digit number (your serial number) if its not there, then try this - With the radio off hold in buttons ' 1 ' and ' 6 ', while holding those in turn on the power button, that should give you your serial number,
* If that still dosnt work then you will have to pull the radio out of the dash and get the serial number off of the back of the radio.
* Once you have your serial number contact your local honda dealer and tell them your situation and they will be able to give you the code to unlock your radio.
Also, you will have to contact your Honda Dealer. The original selling dealer may have the code on file. If not you will have to remove the radio and get the serial number of the chassis. With this serial number, any Honda dealer can provide the correct code. There is no other way to unlock the radio than with that code.
Good lukc (remember rated this).
Jun 30, 2010 | 1996 Honda Accord
Radio reset
The code in the Glove box is just the serial number to the stereo, It is not the unlock code itself. Call a Honda dealer and give them this number. They should give you the code for free. They did for me.
cheers hope that helps
May 07, 2010 | 1998 Honda Accord
1998 Honda Accord EX V6 2 Door - Radio Error Code on Display
No-one is ever particularly happy to here this, but this is the way it is; we do have to keep in mind that the original idea of codes on radios was to prevent people who steal them from being able to use them.
So, if an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code (some people say that they have found the code on a sticker inside the glove compartment, but I wouldn’t count on that). Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release. The serial number will come up in two sets of numbers.)
Some older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number (or you can remove the unit and get the serial number from the back of the radio). Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
Here is the URL for the Honda Owner page. If you register (no charge) you are able to get radio codes using the VIN number of your car, the serial number of your radio, and the
Phone Number and Zip Code that you give them when you register.
https://www.ahm-ownerlink.com/login.asp?page=%2Fprod%5Fhome%2Easp
Hope this helps you with the process.
Jan 04, 2010 | 1998 Honda Accord
Honda acoorrd hybird 2006 ineed code radio
If you don’t have the code, a dealer can access your code with your radio’s serial number. To access the serial number, turn the radio on. It must display ‘‘CODE’’, then turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.
(Some people find the code on a sticker inside the glove compartment)
Hope this helps you.
Nov 11, 2009 | 2006 Honda Accord
Unlock radip code,1998 honda accord 4 door
if you do not have original anti-theft radio code you will need to remove radio and retrieve s/n off of radio. once you have that you can go into nearest honda dealer and with s/n they can give you correct radio code
Jun 05, 2009 | 1998 Honda Accord
I need the unlock code to the radio.
Find the 5 digit radio code or remove the radio to get the serial number. A Honda dealership can get you the code if you have the serial number.Or they can get both.
Apr 14, 2009 | 1993 Honda Accord
Radio unlock code
I need help fixing my radio on a 2006 Honda Accord...I could not find the code and after so many attempts my radio is saying ErrE and now i have found the code and now i can't start over with codes again....what can i do?
Aug 26, 2008 | 2006 Honda Accord
Honda Accord Radio code
Hi all! I have solved my radio dilemma. I took the dash apart and found the manufacturer sticker on the bottom of the radio. It has the serial number on the sticker. You need this number when you call the Honda dealer and tell them your problem. I simply called and explained what happened to the service department of my local Honda dealer and gave them the serial number I found on the radio and they gave me the code for no charge. They just put the number in their computer and VOILA! out came the five digit code(which, by the way, is probably the same for all Honda Accord EX and the same Acura cars from 1994 to 1998 that have a casette player/radio. The code is 21543. Try it if you are having this problem and own the cars with said dates above). Hope this helps someone else.
Mar 03, 2008 | Car Audio & Video
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
