Question about ViewSonic VA902b 19" Monitor
I have a ViewSonic VA902b that will flash a good screen if I turn if off and on but otherwise just black. I traded it out with the monitor from another computer and it does the same thing on the other computer.
  • jklumb Dec 09, 2009
    Thank you. I plugged the monitor directly into a different outlet, not on a surge protector. Problem persists. Do I need to take it to a repair facility to have it tested?
  • ViewSonic Master
  • 19,396 Answers
Hi.
To start test the problem on a different main outlet, if the socket or the network in the house is not well earthed you may get this problem.
The problem is given by an internal faulty component, probably a faulty capacitor.
When you unplug and plug back, the electrostatic charges in internal circuit will get drained, and this will compensate the fault.
The monitor must be tested at component level to find the fault.
Posted on Dec 09, 2009
  • Ginko
    Ginko Dec 09, 2009
    Hi.
    As I said, if the monitor keeps turning off, and you have to disconnect power each time, then there is an internal fault.
    Faults that can cause this problem are:
    PSU ( faulty capacitor)
    Main board (overheating, logical fault, faulty component)
    Inverter (faulty component, defective oscillator)
    Many Viewsonic products are warranted for three years from purchase.
    Contact http://www.viewsonic.com/support/&ei..." target="_blank" rel="nofollow" >Support at this number. Or use the form:
VA902b monitor will flash on for half a second and then go black even though the light shows green. Didn't have any problems with the monitor until updates were automatically installed for windows....
The "sleep mode" is probably set too low.. or a "power saving" mode is set too cut off too quick..(sorry for the low information) .. I am at work on an Apple.. geeezzzz :(
Jun 06, 2017 | ViewSonic VA902B 19" LCD Monitor
Acts like a faulty cap it turns on and then a brief flash the goes black
Yes, very likely to be bad caps:<br /> <a href="http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA903B/">http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA903B/</a><br /> <br /> Just like all other failed VIEWSONIC and all other monitors as shown in my albums.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <a href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><span style="mso-spacerun: yes"> </span>http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | ViewSonic VA902b 19" Monitor
Need Cable Connector for VA902b monitor
Any PC repair shop should have this standard VGA DB15HD cable. Or just go online, it is just VGA CABLE 15-PIN/3-ROW male to male.
Apr 05, 2010 | ViewSonic VA902b 19" Monitor
My Viewsonic VA902b monitor screen turns black anddoesnotrespone
That is a problem of inbuilt display card it does not support to games. You have to open the system case and install AGP card in the AGP slot AGP card is available in any shop of computer your other problems will also solve
Mar 09, 2010 | ViewSonic VA902b 19" Monitor
I have a viewsonic va902b screen when I turn it on the picture flashes and wont stay on the screen, how do I fix it?
More likely to have bad caps in the power supply, that is the first place to check for bad caps with bulging top, it can also be bad inverter circuits, or bad lamps, open it up and post back what you see so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | ViewSonic VA902b 19" Monitor
When I turn on my ViewSonic VA902b it flashes the
The problem can be in the backlight inverter circuits, look fo bad caps with bulging tops, look to see if you do have 12vdc feeding the inverter circuits. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | ViewSonic VA902b 19" Monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
ViewSonic Monitor Flickers
Check your MAC's standby, power and screen saver settings
Nov 13, 2008 | ViewSonic VA902b 19" Monitor
ViewSonic VA902b 19" Monitor Logo
237 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
