Question about Hyundai ImageQuest L70N 17" LCD Monitor
L70N Monitor driver
Is there a current driver update for the hyundai imagequest L70N monitor?
Http://driverscollection.com/?file_cid=24622933713hBuWizS5I1EwOBkI
Posted on Dec 20, 2008
Hundai Imgaequest L70N keeps showing " video mode not supported"i What went wrong? . It is in standard refresh and I can't change it. I can restart in safe mode but then what+
If you restart in safe mode, you need to go to the display settings, and choose a resolution that will work. When you restart back into normal mode, this setting should be retained, and you will be back to normal.
Aug 04, 2011 | Hyundai ImageQuest L70N 17" LCD Monitor
My hyundai imagequest monitor does not display image and makes a rythmic clicking sound. Any ideas as to why & how to correct?
Tear it apart and inspect the power supply and inverter circuit for bulging capacitors - they should have a flat tops. Replace the caps with identical values.
Dec 08, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
My Hyundai L70n monitor periodically displays a thin vertical yellow line on the left-hand side of the screen & I can't get rid of it. Please help me understand why.
That is a problem with the memory array in the monitor. If it is under warranty, don't even mess with it. Take it in. Otherwise open it up and exercise all the connectors on the logic board inside. That works about 30% of the time. If that does not fix it, then it is terminal. They are so cheap now that it doesn't even pay to try to get the repair parts. They will cost more than a new one.
Nov 18, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
My hyundai imagequest l70n lcd monitor started to started to make a high pitched noise and the screen went black but the green light stayed on but now i plug it in and nothing happens no picture and no...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
I want to install the monitor Hyundai L70N but I don't have any cd
You usually do not need a disk to install a monitor, most of them are plug and play capable. If your getting an image that is blurry and out of perspective you may need to change your display size " standard 17 inch is 1280x1024 " If your on XP you can right click on the empty desktop and go to properties, Under the settings tab you will find options for screen resolutions. If your on Vista or 7 you right click on empty desktop space and go go screen resolution, There again you will easily find your settings for your screen resolution. Click apply and then click OK. If your still encountering problems such as no image at all you may have a problem with the monitor.
May 09, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
Green look
CHECK CABLE CONNECTION TO PC...TIGHTEN IF NECESSARY...IF THAT DONT WORK TRY A SEC MONITOR IF CLEAR U HAVE A BAD MONITOR...IF BAD PIC..THEN U HAVE A BAD VIDEO CARD ON PC
Aug 31, 2009 | Hyundai ImageQuest L70N 17" LCD Monitor
Need a manual
I have downloaded the manual from Hyundai website en_man_monitor_lseries_l52s.zip
Jun 19, 2009 | Hyundai ImageQuest L70N 17" LCD Monitor
Hyundai imagequest B90D orange standby
hyundai will not repair this however a electronic service center aka tv repair may. I can do it as most likely is it several capacitors that have blown. Hyundai is also a little picky to open they are assembled very well actually compared to other monitors (they are difficult to open up) let me know what you would liek to do.
Nov 13, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Hyundai imagequest l90d+
the small board that handles all the buttons sounds as if it has gone bad you should be able to get a replacement on ebay
Sep 29, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
My Monitor
Ok? first what you need to do is to hibernate your computer. You can do that by pressing the power button as long as you need for the computer to turn off. Then you turn your computer back on and press the power button ON THE MONITOR twice but you MUST do this really fast. Then what you need to do is to find a circuit breaker on the back of your computer. switch it to the off position then turn it back on. Then turn your computer on. This should fix your problem.
Dec 31, 2007 | Hyundai ImageQuest L70N 17" LCD Monitor
Hyundai ImageQuest L70N 17" LCD Monitor Logo
727 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
