Question about Ricoh Aficio CL2000N Laser Printer
Error message on a Ricoh 2000 SC441. What does
Error message on a Ricoh 2000 SC441. What does this mean? Just before the message I had a paper jam. Could there be a small piece of paper stuck? I have blown it out with compressed air, but still get the error message. Also, I have used generic refill toner in the past. Does this hurt my printer and could it have caused the problem?
  • rhonda458 Dec 10, 2009
    Could you tell me where the laser mirror and scanner door sensor is?
    New Friend:
  • 99 Answers
SC441 mean scanner or laser unite problem.Open it and clean laser mirror,or clean scanner door sensor.
Posted on Dec 09, 2009
  • 1 more comment
  • yahousewife Dec 16, 2009
    Yea open your printer front cover and see upper in cartridge unite.
  • yahousewife Dec 17, 2009
    You must be clean or service laser unite.When you blown it then some of toner or dust laser mirror dirty.so she show this error code.
  • yahousewife Dec 28, 2009
    You open all cover.Where set your copier toner unite there on the top it has.
Sc559 for Ricoh MP 2000
Jam error detected 3 times in succession 559 1. The exit sensor and the duplex sensor detect a paper jam 3 times in succession 2. This condition can occur when SP 1159 1 is set to 'on'. The default is 'off'. Paper jams can occur for the following reasons. 3. Dampness 4. Paper curl 5. Incorrect paper setting in the paper tray Stripper pawls coming apart
Dec 12, 2015 | Ricoh Office Equipment & Supplies
SC441
This Error belongs to Processing Section, Drum parks, Developer Unit Jam n Hard to move or Transfer belt unit
Sep 26, 2014 | Ricoh Aficio Office Equipment & Supplies
How to open front cover for ricoh aficio c820dn printer as it is displaying message " open the front cover to check the paper jam"
Hi there !
You have to open the front cover means that you have to oper the toner compartment and check for the paper jammed inside.
Did it helps your or you find the paper jammed.
Jan 29, 2011 | Ricoh Aficio SP C820DN Laser Printer
My RICOH AFICIO CL3000 give me an error message SC441, what to do ?
Did you just replace your color PCUs (photoconductor units)? If so, one of the new units may be defective. Try reinstalling the old units to see if the problem goes away (after resetting the machine). If it does, you can replace the PCUs one by one to see which one is bad.
If you still get the sc441 even with the old PCUs (or if you don't have them anymore) install a set of new PCUs and that should fix the problem. On the off chance the problem doesn't go away even with new PCUs, contact your local service company because you may have a bad circuit board, motor, or gear.
Nov 15, 2010 | Ricoh Aficio CL3000 Laser Printer
Ricoh CL3000 error sc441
sc441 is a drum motor error. It could be caused by anything from a faulty circuit board to a bad motor, but the most likely fix (and the easiest) is to replace the color PCUs (photoconductor units) which I believe all come as one set.
Turn the machine off and unplug it from the wall, then install the new PCUs, plug it back in and turn it on. There's a good chance your printer will work fine. If the sc441 error comes back, you should contact your local service company and have them take a look at it, because the problem is either electrical or mechanical.
Hope that helps!
Nov 09, 2010 | Ricoh Aficio CL3000 Laser Printer
Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Jan 21, 2010 | Office Equipment & Supplies
Ricoh MP4000 error code SC441 how do to solve this ?
SC 440/441 Main motor Lock/Main Drive section Jam
tray You the condition
01. Press Clear/stop Key (Yellow Key) 2 tarms
02. type 107 same time
03. Press hold down clear key 5 secend ( red key)
Belinkin 1 on the copy counter left hand side
04. type 5 and press # ,type 810 and press #
05. tarn of the machine and tarn ON the machine.
nasmamtrade@yahoo.com
088-01710-950 340
Jan 20, 2010 | Ricoh Office Equipment & Supplies
Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Feb 20, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error SC441
It means the PCU (CMY) motor error.
Try removing and reinserting properly the CMY PCU drum or replace it with a new one.
Jan 08, 2009 | Ricoh Aficio CL2000N Laser Printer
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Ricoh Aficio CL2000N Laser Printer Logo
904 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
aaron douglas
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
