Question about Bosch DKE93xxUC Stainless Steel Kitchen Hood
Bosch dke 935 90cm hood. light and extractor not working
Have bosch dke 935 90cm hood. both the light and the extractor do not work. is there a fuse internally that i can replace ? any suggestions will be so much appreciated
  • 72 Answers
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Posted on Jan 04, 2010
Please can someone advise how to get at the switch board for a Bosch cooker hood E-Nr DKE 995 A GB and FD 8009.
many of the switches used are of the push in type and have little clips on the sides that need depressed to extract the switch . without the ability to see exactly what you have make it impossible for us to assist . contact an electrician locally .
Sep 21, 2016 | Bosch Kitchen Ranges
Where are the fuses in a Victoriana Deluxe Leisure cooker? The extractor fan and light have stopped working
It would be fused to the house current most likely through a circuit breaker on your service box.
Jul 19, 2016 | Kitchen Ranges
Bosch DKE 997E wall cooker hood doesn't work properly
EN Control buttons separating from control mounting bracket. Affected Countries CA, US Affected Appliances HPCN36NS/01, HPCB36NS/01, HPCN48NS/01, HPCB48NS/01 Fault description / Customers complaint / Diagnostic Codes Diagnostic Codes (DC) The following table contains the diagnostic codes, which most commonly occur in connection with the mentioned fault description. Depending on the actual information from the customer, other diagnostic codes are possible. DC Fault description of the customer 160100X45000 Mechanical damage / Holder Root cause On some Thermador Professional hoods with FD 9407 to 9611, the control buttons may separate from the control mounting bracket due to insufficient adhesive between the control mounting bracket and the inside of the hood canopy. Solution Beginning with FD 9612, wider tape was implemented in production. For units built prior to that time, service kit 12022532 is available. The new repair kit includes the control-mounting bracket with wider tape affixed to it, and four screws. The tape will provide more surface coverage to improve the support of the mounting bracket.
Dec 06, 2017 | Bosch DKE93xxUC Stainless Steel Kitchen...
Install the chimney cover
there should be 2 or 3 peices of alum off the hood predrill hole's then rivet or steel screws
Feb 12, 2009 | Bosch DKE 9365 Stainless Steel Kitchen...
Am buying a Bosch cooker hood - does it come with filters?
filters required only if you are venting inside your house (ie recirculating the air), if it is going outside, then you don't need them.
Jul 26, 2008 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Extractor hood
Unfortunately NO, use the template provided. Please ensure there are no cables running through the walls before you drill.
Aug 07, 2007 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Bosch DKE93xxUC Stainless Steel Kitchen Hood Logo
1,752 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Joseph Hoffmann
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
