Question about Amana Heating & Cooling
Amana central air/heat system has an fp code???? what does that mean?????
4 Suggested Answers
  • 85 Answers
SOURCE: My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Posted on Dec 03, 2008
koolbreezes
  • 540 Answers
SOURCE: my Amana (distinctions) central heat and air unit -loud noise
If this s an Oklahoma Tulsa area call. KOOL BREEZES 918 6878813 for a diagnostic check.
Posted on Dec 06, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Posted on Dec 30, 2009
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
Amana ptac is blowing cold air ot with heat on and showing FP code
This indicates FREEZE PROTECTION. Please look up an operator's manual on your particular model. A quick download you will find easily.
Jan 07, 2015 | Amana Heating & Cooling
Unit shows a code fp. What does this mean?
CODE= FP
STATUS = Freeze Protection Engaged. The room temperature measured by the wirelessremote thermostat or indoor ambient thermistor active sensor falls below 40°F.
SUGGESTED ACTION = No Action required. This setting will disengage when theroom temperature rises above 43°F
Is sit helpful?
Dec 20, 2010 | Amana PTH123B25AJ Heat Pump Air...
Blowing of cold air every 5 minutes, and it says FP on the screen
FP is the code for frost or freeze protection. The unit will automatically do this periodically to prevent any damage caused by low temperatures although it should not be running as frequently as every five minutes. If the outside temperature is not low then it could either be a problem with the exterior thermistor (not the one you see from inside your room) or the control board could be on its way out.
Feb 15, 2010 | Amana PTH123B25AJ Heat Pump Air...
Its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying...
I was wondering the same thing about our unit until I found the specs online and read that it has freeze protection. When the temp goes below 40 degrees, the fan comes on to prevent damage to the unit.
Dec 23, 2009 | Amana PTH123B25AJ Heat Pump Air...
My Amana (distinctions) central heat and air unit -loud noise
Dec 05, 2009 | Heating & Cooling
What does it mean if your central heat and air unit says emergency under the time and date
your emergency heat is on and your outside heat pump most likely is not coming on
Oct 22, 2009 | Amana Heating & Cooling
Service code FP
I know some manufacturer's use the code FP for Freeze Protection.
Jan 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
Unit Won't Cool Or Heat Just Blows Air and Displays FP
fp means freeze protection when gets too cold out unit comes on by itself so pipes dont freeze
Jan 17, 2009 | Amana PTC093B50AJ Electric Heat Air...
Heating & Cooling Logo
543 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
