Question about Symbol MC9000-G Portable Terminal
Freezes on the warm boot screen MC9000 - Symbol MC9000-G Portable Terminal
    Novelist:
  • 75 Answers
This can be for a number of reasons.
First thing would be to try and cold boot the device:-
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger
If that fails next thing would be to try and re-flash the operating system. This is done by using an SD card and loading the latest operating files onto it. The SD card slot is located under the keypad. A cross head screwdriver is required to remove the keypad. Search on symbol software download site for the latest. The download also has a readme with detailed instructions. Once the files are on perform a cold boot.
Remove battery half way, hold power button and trigger, push battery in fully until click and then release power and trigger. Drop the terminal in a cradle so that it runs on external power.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Posted on Dec 10, 2009
    New Friend:
Perfect! amazing!
Posted on Jan 11, 2017
Why does my Janome MC9000 screen not light up, it sews ok, needle works up and down.
It depends on the screen; a few have a small light or lights behind them, but I believe for most modern screens, the lighting is in the screen itself. It sounds as if yours is not working, but it CAN be replaced, and it's not a hard job to do so--although the part may be a little pricey. It's roughly equivalent to the screen of a laptop not working.
This is definitely a job for a technician.
Sep 13, 2014 | Sewing Machines
Cleanbootandblank de la mc9000
Si es Windows CE5, no se puede hacer cleanboot and blank. Necesitas cargar el sistema operativo de nuevo. Si es Windows Mobile 5, te puedo pasar los archivos para hacer clean boot.
Jun 12, 2014 | Symbol MC9000-G Portable Terminal
Touch screen for MC9000
the motherboard could be going out the machine would need to be checked
Mar 15, 2012 | Janome Memory Craft 9000 Computerized...
I have a problem at start of motorola mc9000
I have a MC9000 and the start up screen stays on. How do I get pass this screen and get back to scanning?
Apr 25, 2011 | Motorola MC9000-K Portable Terminal
Wont boot up pass the first screen
Check your charger, The charger which connects to your home power outlet is better than a USB one. So charge it for at least 30 min or with a borrowed charger incase yours is damaged and try again
kc
Feb 24, 2011 | Motorola MC9000-K Portable Terminal
Touch panel freezing after approx 5 to 10 minutes operating
Your machine is a "computer" and needs a qualified Janome repair tech.
Mar 24, 2010 | Janome Memory Craft 9000 Computerized...
Hello jumpmaster. When an MC90XX does this, it means that something has gone wrong with the Operating System file execution. Sometimes a cold-boot can fix it (instructions below). If not, then there is a problem with the OS files. If you purchased your MC90XX from Motorola/Symbol you should be able to download a copy of your OS to reinstall. The file will include a readme.txt that will walk you through the process. I hope this solves your problem. Good luck!
  • To Cold Boot
  1. Press the primary battery release to partially eject the battery.
  2. While the battery is partially released: simultaneously press and release the trigger and power button.
  3. Push the battery back in until it clicks.
  4. The MC90XX should power up and start it's boot-sequence.
Dec 07, 2009 | Symbol MC9000-G Portable Terminal
Symbol MC9000-G Portable Terminal Logo
11,817 people viewed this question
Top Symbol Computers & Internet Experts
 Brian
Brian
George Etukudo
George Etukudo
Norman Al-Anbar
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
