Question about Digital Square Shuttle PA50 MP3 Player
Rhomba PA50 only turns on in recovery mode (connected to PC)
I'm only able to start this CREATIVE RHOMBA when I connect it to PC in recovery mode with the "hold key on". Whenever I shift the hold key back to off (even if its connected or not) the players powers off
Creative zen v plus. when i turn on it says its in recovery mode thats all it will do i reformated it but it does not allow me to put music or anything else on it
Connect you player to your computer and use the recovery tool provided by creative labs.
Recovery tool: download here
You'll have to reflash te firmware with this tool.
When the firmware is lost on a zen or any other creative labs mp3 player, the mp3 player boots into recovery mode.
Note when doing this, all data on the mp3 player can get lost.
Aug 27, 2009 | Creative Labs ZEN V Plus MP3 Player
My Creative Zen Touch is frozen. When I hold down the "Menu" button, the screen does not change. When I connect to the computer and attempt to run Creative Mediasource Organizer, I get a message that the...
I would run the recovery console from the player itself. Make sure the Touch's power supply is plugged in (and unplugged from a PC) then to access the recovery mode of the Touch, hold down the Play/Pause button while inserting a straightened paper clip into the reset hole on your player, give it about five seconds then remove the paper clip.
Next, keep on holding the Play/Pause button until the Rescue Mode screen appears. After you see the rescue mode menu, you can release the play/pause button.
I would try a "clean up" first, as this is less intrusive and will not erase data.
Mar 27, 2009 | Creative Labs Zen Touch MP3 Player
My 16GB creative zen is on recovery mode after installing an upgraded soft ware
You must give it the firmware upgrade from support.creative.com, or it will not be able to get out of this mode. Support.creative.com
Creative Zen
Try another PC or another USB port
Make sure the hold/lock is not engaged
Reset
Check for firmware update on Creative's website
Get Recovery Tool from Creative
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If all else fails, check with this guy:
http://www.mycreativefansite.com/2007/05/myzenchecker-tools-guide-to-problem.html
Creative Zen – Formatting
Step by step instructions for formatting a player
1. Detach the player from the PC if it is connected, and turn off the player.
2. Press and hold the Play button while powering on the player.
3. When the player displays the Creative logo, release the Play button
4. Select Format (All) and select Yes to format the player.
5. After the player has finished formatting, select Reboot.
6. Re-transfer the tracks to the player.
-Tha Mp3 Doctor
Sep 14, 2008 | Creative Labs Zen Digital Media Player
Creative Rhomba mp3 player
I solved the problem by going onto the creative web site where they have archived instruction manuals for all their products
Jul 26, 2008 | Audio Players & Recorders
Getting out of recovery mode
The recovery tool mentioned above is not designed for the sleek photo. You need to download the firmware for the sleek photo from creative's site. Now we need to get your player recognized to get the firmware loaded. If you have Windows Media Player 11, it needs to be removed. Also remove WMP runtime. After that, restart the pc and your player should be recognized. You can then double click on the firmware program to run it. It might say something like, this firmaware is already installed...do you want to reload it? Click yes to reload.
I had the same problem with my sleek photo. Once I got rid of WMP and the runtime everything worked like a charm.
Jul 02, 2008 | Creative Labs ZEN SLEEK MP3 Player
Recovery mode
to reset this player -- take out the battery and put back again.
In the recovery mode do the following: format the HD, clean the firmware. If those two go smoothly, go to creative.com and download the firmware, connect player to PC(still in recovery mode) and run the downloaded firmware.
Jun 21, 2008 | Creative Labs Zen Micro MP3 Player
Assistance for drivers
Click here and that that is the driver for the Rhomba.
Enjoy,
Lee
Jun 16, 2008 | Creative Labs Rhomba MP3 Player
Recovery Mode
· 1. remove all creative software from your pc (do this from start menu/settings/control panel/add or remove programs)
2. Uninstall Windows Media Player 11 and Windows Media Player 11 runtime. This will rollback the pc to an earlier version of WMP.
3. Download the latest version of the zen driver from this location:
http://us.creative.com/support/downl...ame=Windows+XP
4. Make sure the zen is not connected to the pc and install run the exe file to install the software on your pc. at some point, the install will tell you that the unit is not connected. Connect the unit to proceed. it will also notify you that you are replacing an existing software, or something to that effect. I accepted or said OK to this popup. Once the firmware is installed, my started to work fine. You can now reinstall WMP from microsoft website. Hope this works for you.
All else failes download the recovery tool from creatives website.
Aug 02, 2007 | Creative Labs ZEN Vision:M Digital Media...
Player is in Recovery Mode
ode
Digital Square Shuttle PA50 MP3 Player Logo
108 people viewed this question
Top Digital Square Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digital Square Audio Player and Recorder Expert? Answer questions, earn points and help others
