Question about Farenheit DVD-61 Car DVD Player
The dvd player has a parental code locked in. Is
1.The dvd player has a parental code locked in. Is there a default code or a way to overide the current one?
2. One of the monitors display itself upside down, Is that a wrong connection or a bigger problem?
Steve
Southern California
  • 547 Answers
The default password is 0000 (four zeros)
Crutchfield has a scan of the manual online here, but it doesn't say anything about how to reset the system password. Hopefully the default one will work for you.
Please remember to hit the "thumbs-up" to rate my solution!
Posted on Dec 09, 2009
  • Rob C Dec 09, 2009
    Oh, forgot to answer the "upside down monitor" part.
    This unit sends NTSC analog video out, so there's not a setting to flip one of the displays. If the image is upside down on one of them, then I think that monitor must be installed upside down. I can't see any technical way for the DVD player to show one image inverted and one right-side-up.
Does anyone know the password to unlock parental lock on a Copy DVD R1300? Tia!
The parental lock is not on the DVD, it is on the player itself. Only mummy and daddy can turn it off. The player reads the parental code on the DVD and the DVD Player locks access.
Jul 05, 2016 | Televison & Video
How do I restore Toshiba DVD player SD3990 back to original without password? Forgot password.
If you forget your 4-digit code
If you forget your password, to clear the current pass-
word, follow the procedure below.
1 Press SETUP to display the setup menu.
2 Use the Number buttons to enter the 6-digit number
"210499".
The 4-digit password is cleared. "P CLr" appears on the
display for a moment.
3 Enter a new code as shown above to the left (Rating)
Dec 05, 2014 | Toshiba SD-3990 DVD Player
How do I override the current parental code setting on my PS2?
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Nov 28, 2010 | Sony PlayStation 2 (PS2) Console
My DVD player is locked, the display shows a red key.
Hi, This sounds like a parental lock issue. Try going into the set up menu and press the down key choosing custom by pressing enter (this is in the user manual page 20 - 22) then go down and select parental. If you know your parental control password code then enter it, if not the reset code is 4737 you will then need to create a new 4 digit code,There are 9 levels to choose from 1 - 8 and all, all being the selection that removes the parental lock. Hope this helps. James
Apr 21, 2010 | Sanyo DVW-7100A DVD Player/VCR
Cannot remember my parental control number is there an overide
try this:
Apr 12, 2010 | Sony PlayStation 2 (PS2) Console
JVC XV-M555 DVD player has the parental control set somehow. Need to know how to disable the parental control on this DVD player
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
Jan 01, 2010 | JVC XV-M555 Multi-disc DVD Player
Bought a used playstation 2-need to get parental
If this does not work, the other code is usually 0000. However if they change the default password, then it will be hard to find out.
Sep 10, 2009 | Sony PlayStation 2 (PS2) Console
I need the overide code for my ps2 that I brought used
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under GA_googleFillSlot("TL-IMU-Article"); custom setup.
Nov 18, 2008 | Sony PlayStation 2 (PS2) Console
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
Zenith DVD Parental Lock
Try power on the player with no disk in the drive. Press "PAUSE" on the remote. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display). Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.) . Press "PAUSE" on the remote. Power the player off and then back on
Feb 17, 2008 | Zenith DVC2200 DVD Player
Farenheit DVD-61 Car DVD Player Logo
177 people viewed this question
Top Farenheit Car Audio & Video Experts
Martin Clarke
Martin Clarke
afairman1927
Are you a Farenheit Car Audio and Video Expert? Answer questions, earn points and help others
