Question about Kenmore 63942 Dryer
Kenmore series 80 electric dryer not heating
Kenmore Model #110.96581210. The dryer tumbles, runs and it appears that everything else is ok, except it does not heat. This started last week. I want to make sure it is the heating element and not something else. Should I look at replace the heating element or check for something else. Also, if it is the heating element can you give me an illustration as to what I need to do to replace? Can you help?
  • Kenmore Master
  • 19,396 Answers
Hi.
You do not know if the problem is the heating element.
Ensure that you have checked the Thermal fuse.
Parts that can cause no heat are heating element, thermostat and electronic control.
If the machine is functioning, then concentrate on heating element and thermostat.
The heating element must be tested using a multimeter. The multimeter set on Ohms, at Rx1 must be used on element contacts, to read impedance.
To test thermostat better removing parts from the appliance, after disconnecting power. To test element you will need to at least disconnect its wiring.
If the element is good it must return some impedance that is not infinity. If the element returns open (infinity), then element is bad.
Same for the thermostat, only difference the thermostat must return low or no impedance (zero) at room. If impedance stays infinite (open), then the thermostat is faulty.
If the machine has separate thermostat and high limit (they are same thing on dryers), both thermostats must be tested.
If there is some cooling, but cooling is poor, check also lint filter, air duct and fan.
All testing and repair must be done by a trained person.
Here all parts and diagrams for your model:
Parts:
Element
Thermostat
Cutoff-tml
Posted on Dec 09, 2009
2 Suggested Answers
  • 744 Answers
SOURCE: Hello, I've got a Kenmore 80 series dryer Model:
Check for lint clogging first. Pull the unit away from the wall and look to see if there is an excessive build up of lint at or near the discharge vent or into the vent line. Clean as needed. If it's really clogged you may have to remove the back cover.
If no joy, then check for a bad thermostat. There should be two. They are located on the discharge vent near the dryer exhaust blower. You will have to remove the back cover of the dryer to get to them. Check the stats for continuity. MAKE SURE the power is off before working on the dryer.
It's much more likely to be on of the two items listed above, but if the dryer isn't clogged and the stats are both good, check the heating element.
Posted on Aug 20, 2010
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
My 80 series Kenmore Dryer is heating up, tumbling, but my clothes aren't drying. It's taking 6-7 cycles to get anything dry, I have checked the vent hose and everything. All seems to be checking out ok....
You need to check your vent, or your vent system in your dryer. You also need to check to see if your clothes are tumbling. If not then your belt could be broke. Good luck!
Aug 21, 2010 | Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
Kenmore 80 series HD+ dryer will not heat. dryer runs and tumbles fine just no heat
Check thermal fuse behind the dryer by opening the back cover.Fuse is on the air duct.
Jun 18, 2009 | Kenmore Dryers
Kenmore 80 Series Model #110.74842400 Series MR5112733
There's a few things on this dryer that can stop it
from heating. 1st thing your going to need is an ohm meter, your testing simply for continuity. The main items that cause no heat at all on this gas dryer is the igniter on the gas valve, the thermal fuse located on the blower wheel housing the thermal cut out located on the burner box or the flame sensor on the burner funnel and lastly the coils on the gas valve. the sequence is from most too least common. Of course unplug it and shut the gas off.
Jul 30, 2008 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 63942 Dryer Logo
125 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
