Bell & Howell B we Bell & Howell Spectrum XF 8120D Logo
Posted on Dec 09, 2009
Scanner is scanning slow - Bell & Howell B we Bell & Howell Spectrum XF 8120D
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
158
Points
Likely your resolution settings are very high, anything scanned at over 100dpi will take considerably longer. if it were a hardware issue then the scanned document would not be readable as the speed of the rollers must be sync'd with the scanning speed for a successful scan
3answers
Slow save on pdf file with capture perfect3
Change the scan resolution to 200 dots per inch (200 dpi). If 300 it tajes a few seconds. If 1200 dpi, it may take really long.
2answers
Hi, I scan documents (recto and recto-verso) using the InformatikScan software and the scanner Canon DR-9080C. When I scan for ex. 30 pages, after 10 pages the scanning process slows down in...
The scanner creates a Raster Image and if it is grey or color, the size is big. After a few images are scanned, the 'buffer' inside the scanner is full. It may take more time to process the scanned image by the scanner if it is 24 bit color. The image is sent to the computer Harddisk and if the disk is full or if it had not been defragged for a long time, the sectors may not be contiguous for speedy writing, This will slow up the scanning. Ensure the disk has large space. 'Scan ahead' slows down scanning speed. (Without scan ahead, the next page is fed only after processing, whereas when selected, just after the previous page is scanned, the scanner start the next one)
S. Mohan, India, Chennai
2answers
My canon dr-3080 cii is running at a low speed. it was at its maximum and suddenly slowed down. rebooted cpu and switched scanner on /off and chcked settings with no results. please help
Scanner will continue to scan at the same Speed! The problem is in the computer. Check if you have enough disk space, do a 'defrag' on your harddisk, create extra space by deleting unwanted files. IF your processor is slow and if you are scanning in color or converting to PDF while scanning, it may slow down the output.
S. Mohan, Chennai, India
2helpful
Canon scanner speed slow
Various ways....Try these! the slow problem wil get off
How to change the resolution (Windows)
The precision of printouts can be improved by changing scanning resolution.
The higher the scanning resolution is, the more precise the scanned images are represented, however, the file size gets larger.
The scanning resolution can be changed before scanning photos.
Note: When the scanning resolution is doubled, the image data size will be quadrupled.
When the data size is large, the throughput speed may slow down or may occupy too much of the computer's resources (memory).
<Procedures>
Memo: The following is explained using MP Navigator 3.0 procedures.
To scan using MP Navigator:
1. Launch MP Navigator and click Photos/Documents (Platen) on the Scan/Import tab.
80006642en_05sj00759_en_00.jpg- The window you see varies according to the printer model.
2. When the Photos/Documents (Platen) window is displayed, click Specify.
3. When the Scan Settings window is displayed, select the resolution in Scanning Resolution.
If necessary, set other items as well.
4. Click OK.
5. In the Photos/Documents (Platen) window, click Scan to start scanning.
6. Changing the resolution is completed.
To scan using the scanner driver:
1. Launch MP Navigator and click Open Scanner Driver on the Scan/Import tab.
80006642en_05sj00765_en_01.jpg- The window you see varies according to the printer model.
2. Change the resolution.
According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
- To set the resolution in Simple Mode:
(1) Select the Simple Mode tab.
(2) Select the output resolution from the Destination pulldown menu.
If necessary, set other items.
- To set the resolution in Advanced Mode:
(1) Select the Advanced Mode tab.
(2) In Output Resolution, select one of the preset resolution, or enter the number from 25 to 19200 to specify your favorite resolution.
3. Click Scan to start scanning.
4. Changing the resolution is completed.
IT WILL SCAN FAST AFTER 10 PAGES IT WILL RUN SLOW
Your disk must be full or you need to do a 'defrag' on the volume where you are storing the data. Initially it is stored in the buffer and when the disk writing is slow, scanning speed is affected. Clean the disk for faster scanning.
Scanning speed slows down after approx 100 pages. Is it possible to talk to a 1220 expert on phone to describe multipule problems, today?
Scanner 'slows' down depending upon various conditions. For color images and large detailed files, there may be some slowing down. The most common cause is insufficent disk space. Check where you are directing the computer to write the scanned images. Have sufficient space and do a 'defrag' done.
S. Mohan, India.
Canoscan LIDE 25 using Vuescsan software
The first scan is 'pre-scan' and the second one is the real scan. The pre-scan shows you a rough image and you can check borders etc. Look for options and switch off 'Pre-scan' S. Mohan, India
1helpful
Scanning speed slowed...
did you change your scan resoulution? The quality of your scans will determine how slow it will pass through. another thing to check is weather it is scanning both sides, another option in your scanner properties.
SLOW SCANNING
What a Useless Waste Of time.......... Where are the drivers?????????
Top Bell & Howell Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Bell & Howell Office Equipment and Supply Expert? Answer questions, earn points and help others
