Question about Sony KP-51HW40 51" Rear Projection Television
After turning on it has normal color then turns blue slowly. what do I do to fix it. Is it the bulb?
    Top Expert:
  • Sony Master
  • 14,553 Answers
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now only available on a rebuild basis--usually not worth doing as the cost is very high.
You may have a bad blue picture tube but there is a way to deal with this first----the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue)
Someone has to remove the entire piece on the frontof the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a videoinput After turning on it has normal color then turns - clip_image001.gif with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 -500 parts and labor.
I do this here for free so if this has helped you rate this solution.
SD TECH
Posted on Dec 09, 2009
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2013 | Home
Covergence problems or alingment , its has three colors without alingment please help me!!!
manual convergence should fix the problem if it does not the set most likely either has a bulb burnt out or a bulbs power / focus needs to be adjusted by taking off the panel and finding a 6 screw control panel
should look like that 3 screws in a row on top of another three screws each of thees control the power and focus of each color this is a somewhat delicate process and is a huge pain on larger tvs that you cannot completely see the picture or color while you are directly under in front of it so I had my gf come in the room and sit across to let me know which color was doing what if you dont have someone you will need to check after each adjustment
now the diagnostic
as i said each screw controls a colors power and focus the focus is used if you see an outline of a color around pictures if everyone looks like a dead jedi with a blue aura around them the blue focus needs to be adjusted and so on for each color if you skies or blue screens seem feint your blue power probably needs to be turned up and so on for each color
if through the course of this you can see the bulbs and notice one is out your probably looking at dealing with the color issue until the time you can purchase a new tv as the cost of the bulb and the technician needed to install it as they are wired to a circuit board and requires technical knowledge and tools
hope this helped
Robb
Apr 29, 2010 | Zenith R57W46 57" Rear Projection...
I replaced the bulb on the unit and still have a blue spot on the screen of my Panasonic MODEL PT-52LCX35
most likely needs to be manually adjusted
now the diagnostic
hope this helped
Robb
Apr 29, 2010 | Televison & Video
How do i fix the color on my tv?? Very blue
Reset it to factory colors setting,turn colors down to -5 or 40 percent should be normal,still very blue than ur video backlight board is dying must replaced.
Dec 15, 2009 | Panasonic TC-32LX85 LCD TV
Blue haze/cloud in center of screen, slowly spreading
how to fix my problem Blue haze/cloud in center of screen, slowly spreading .but last time my lamp broken I order by my self and fixed now I have the blue color in my screen please let me know what is the problem may be I need to replaced same parts please let me know how to fix thank you
May 13, 2009 | Hitachi 55VS69 55" Projection HDTV
2003 ford ranger 7 pin wiring for a trailer all I need is what the colors on the wiring are blue/yellow/green/black/brown/white
White is ground, black is power to trailer battery trickle charge, blue is brakes, green is tail/running lights, red is left turn signal and left brake light, brown is right turn signal and right brake light, yellow is aux power/back up lights. This is the general color coding, there are exceptions, white, black, and blue are pretty much always as listed above, sometimes the others vary. If you find you are having trouble, post any further questions here, I'll be glad to help out. Curt
Apr 24, 2009 | 2003 Ford Ranger Regular Cab
Blue bulb is lit but no picture
the messed up colors are probably from a burned out convergence chip. not too pricey to fix.
Feb 17, 2009 | Philips 55PW9363 55" Rear Projection...
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
When tv is on it just loses all color but blue
the tubes are going out on you,probably time to replace them
Oct 27, 2008 | Sony KP-51WS500 51" Rear Projection...
Toshiba 65hx81 65" Rear Projection tv. black & white color/green
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Sep 05, 2007 | Toshiba 65HX81 65" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
195 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
