Question about GE (PSS26MSRSS) Side by Side Refrigerator
Auto defrost not working
Our GE side by side refrigerator model TFX20JRBGWW appears to not be defrosting properly. Therefore, the coils in the freezer section are frosted over and the refrigerator section is warm. Will a manual defrost help this problem and bring the auto defrost cycle back on again?
Any advice would be greatly appreciated.
  • 3 more comments
  • JHeff Jan 19, 2008
    Model year about 1998
    Unit is defrosted for now.
    Do I just need a new Defroster Thermostat?
    about a 1998
    Will a new Defrost Thermostat help?
  • dawn48 Jul 28, 2008
    Our HotPoint/GE HSS25IFMDWW Serial Number md201796 side by side referator appears to not be defrosting properly. therefore, the coils in the freezer section are frosted over and the refrigerator section in not that cold and the ice is not solid.
    Any suggestions or advise?
  • keith777 Sep 25, 2008
    I HAVE THE EXACT SAME PROBLEM
  • Anonymous Mar 31, 2014
    there is frost inthe refrigeration coils anr the heating does not appear to be working
    President:
  • 1,314 Answers
A manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
  • robert samples Jan 19, 2008
    and forgive my spelling lol
    just a sec will be right back to you
GE side by side refrigerator not working properly. Fresh food side is warm. Freezer side is at 9 degrees. What could be the problem?
Check for ice buildup at back of freezer. If so then auto defrost mechanism is not working. Check for bad defrost timer, heater, and defrost thermostat.
Oct 17, 2015 | GE Refrigerators
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Each side won't get cold. food starts to spoil
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Jul 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling properly GE TFX20JR i tried the defrost timer and it is working, now what other possibly problems could there be? thanks!
Do you have ice /frost buildup on freezer wall?If so auto defrost is not working.3 possible causes ,turn the defrost timer manually to defrost position either measure amps @ 3.5 amps or listen in freezer section for crackling popping or sizzling.If you dont hear/measure this you have a bad heater or defrost tstat .Remove freezer wall look at top of coil for thermodisc 2 wires and 1 or 2 glass heaters (btm,mid coil).Tsat can be bypassed by connecting the 2 wires or checked for continuity closed at approx 20'.heaters may be visibly burnt or broken recommend changing both parts
Jun 19, 2009 | GE GSH22JFR Side by Side Refrigerator
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
Frost in Freeze
Hi Frezer Frost.
It sounds like your defrost circuit in the refrigerator has gone south. This melts the ice off of the cooling coil in the freezer section every 8 - 10 hours of run time.
If you are old enough to remember the manual defrost refrigerators, that is why you had to defrost them occasionally. The ice layer on the coil acts as an insulator, preventing the coil from working properly.
Greg.
Aug 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Jul 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Apr 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
445 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
