Question about Akai PT4298HD Rear Projection Television
The top and bottom are pulling togeather at the top and bottom like a hourglass and the colors are pulling togeather hope this is and easy thing to fix! Has the effect of making it looking double vision
  • Akai Master
  • 5,138 Answers
Replace both of your STK ICs big black ICS will have part number on them and theres 2 resistors near ICs 2.7ohms replace them also Call Mats for Parts 1-800-628-1118 Example STK392-020 this might be number of ICs if so use 040s
Posted on Dec 09, 2009
SOURCE:
I replaced my coupler on my kenmore 80 series washer its all togeather on bottom but putting the pieces back togeather inside i forgot how to put it togeather.
what part are you stuck on?if you have the motor and pump back on next slide the frame back on,tilt the frame so the bottom front panel slides under the front frame part then drop the back down,,ssceck the back corners to make sure it locked in correctly,if you can pull out the side panel tilt the frame back and push the side panel in as it slides down,the sides usually line up,pop the metal clips back in place,plug in the lid switch harness,flip the top console back down and put in the two phillips screws in,plug it in and you should be good to go.
Jan 08, 2011 | Kenmore 15864/15862 Top Load Washer
My hydrant is leaking water from the top and sounds like it is.
the little rubber gasket under the plastic cap is broken remove the plastic cp pull out the little white plastic piece flip it over remove the o ring and put in a new oen then put it back togeather.
Mar 15, 2009 | Halex Liquid Tight 90 Degree Elbow, 3/4"
I CAN'T PULL THE T-SHAPED THINGS IN THE RIGHT ORDER .
ok u have to go the far right one first then the 1 nest 2 the far right. the the other right, then the other left.i have that game.
Feb 09, 2009 | Nintendo The Legend of Zelda: Phantom...
Nintendo DS The Legend Of Zelda
First of all, this crest is VERY difficult to draw correctly
But have you ever tried to draw the hourglass instead?
Sep 26, 2008 | Nintendo The Legend of Zelda: Phantom...
Mitsubishi vs50805
That is the classic symptom when your convergence ICs go out. They usually take out the two resistors that drive the ICs as well. This is a easy fix if you can solder. Your ICs are located on a large heat sink on the left side of the chassis they will have an STK392-110 number or similar number. They cost about 10.00 each. Let me know if I can assist you with any other info.
Jan 24, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Legend of Zelda - Phantom hourglass
<img src="http://www.1up.com/flat/MyCheats/Zelda%20Hourglass/1_2re/zelda041.jpg" img>
draw an hourglass shape (like a figure-8 with a flat top and bottom) that starts from the top left corner (1), across (2), diagonally down to the left (3), across the bottom (4) and back up to connect with the starting point (1). If done correctly, the hourglass shape on the door will glow and let you through
Jan 12, 2008 | Nintendo Game Boy Advance Console
Hourglass effect and fuzzy
You have a convergence problem and I suggest to get a qualified honest tv repairman because this is a highly technical problem in this model. Hope this helps
Dec 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hourglass Picture
it easy to locate the fusible resistor in the power module PCB,it look like a resistor but white in color,normally printed soc xxxx (2100) on top of the component. After you replaced the STK392-110 , you need to re-alight the convergence setting again.hope it will help.
Aug 03, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Akai PT4298HD Rear Projection Television Logo
97 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
