Question about Epson Aculaser C1100 Printer
Display shows worn YK Dev Unit and the printer has stopped. When I open the front the cyan cartridge is showing. Can you advise on what is needed Thanks
    New Friend:
  • 99 Answers
You need to change cyan & yelloe cartridge.Buy new cartridge.Fix your problem.
Posted on Dec 09, 2009
When i turn on the machine,error shows on the screen,development unit is not installed properly
1. Defective electrical connection for the TD sensor.
2. TD sensor not installed correctly
1. Take out the dev unit
and put it back in. If that
does not work, replace
the dev unit.
2. Press the TD sensor
firmly against the frame
of the development unit.
Jan 02, 2016 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
WHAT CAN I DO WHEN WORN YK DEV UNIT MESSAGE APPEARS
People think about it. Contact the manufacturer of your specific model for the error codes or order an manual from them. Most people seem to soft to actually do the research. If a company has fallen from grace I can see the extra outreach but look it up. I can.
Apr 21, 2015 | Epson ACULASER CX11NF All-In-One Printer
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
Ricoh Aficio 3800C: How do you clean the Development Unit Hello, I have a Ricoh Aficio 3800C. I noticed that there are faint Cyan streaks when I print. I opened up the printer/copier unit and looked at...
I believe what you are referring to is the drum inside the toner cartridge. The drums are usually very strong colors, blue or green and if it is streaking then the drum cleaning blade has failed on the inside and you need to replace the cartridge.
Feb 14, 2011 | Ricoh Aficio AP3800C Laser Printer
My cyan cartridge shows as empty. My black
No. You need all the cartridges installed with functioning chips for your printer to work. The reason why you need all the colors when all you print is black is because a small amount of color prints when you print black. The manufacturers want to make up their R&D costs on the printers by selling lots of expensive ink.
Nov 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Hi there, need your kind help. My Hp laserjet 5550 has a missing colour problem. Cyan is missing in the print out, giving rise to to blue and green colours being absent in print-outs. Scanner is confirmed...
Cyan cartridge is OK, means that the display shows the level of toner in the cartridge, right? Then chip it is ok.
Try another cyan toner, the printer may be that it has broken the opening flap of the laser. Or check if the laser's flap cyan is blocked.
Nov 14, 2009 | HP LaserJet 5550 Printer
Printer shows worn dev unit what is this please
The dev unit (developer) is the part that the ink toner cartridge fits into, one for each colour (K-black, C-cyan, Y-yellow, M-magenta). Two things wear out on dev units, the bearings at each end of the developer roller or the roller itself. The roller is made of metal and is magnetised so a thin film of toner sticks to it, the magnet is recharged by electrical "rubbing" contacts inside the printer as the drum rotates. Gradually the contacts rub away and so the roller loses its magnetism, this will be noticed by an increasing amount of toner being spilled inside the printer. The roller bearings speak for themselves, gradually the roller will become more & more difficult to turn smoothly and so the toner will not be evenly distributed. The only way to fix this is to replace the worn dev units although cleaning the contacts will help to preserve their life.
Jul 08, 2009 | Epson Aculaser C1100 Printer
I changed my cyan cartridge in my Brothers LC-51 printer. The display shows No cyan cartridge. Will not print. Replaced with the old cartridge got the same message.
Same issue for lc-51 printers:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc440cn_all
Jun 15, 2008 | Brother Office Equipment & Supplies
K toner low
C - is for Cyan
M - is for Magenta
Y - is for Yellow
K - is for BlacK
Jan 25, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
848 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
