Question about Radio Communications
How to program regency model 1070 scanner? I program scanner,yet unsure why no ''frequencies'' stop.Only zero flashes>
    President:
  • 2,761 Answers
I couldn't locate a manual for you, but this vintage 10-channel unit is fairly simple to operate.
Start by turning the unit on with the POWER button.
Push the MANUAL button.
Push MANUAL until you see the Channel you want to enter the frequency in -i.e: Ch 1, Ch 2, etc.
Enter the frequency with all the digits needed - i.e: 44.94 / 44.98 / 154.965 / 155.610 etc
Push the ENTER button. The frequency will now be in the Channel "Ch" you chose.
While still in the manual mode - go the the channel you expect to listen to most - then push "DELAY/HOLD". This will hold the scan so you will get the reply from the dispatch unit to the receiving unit.You can set this feature on any or all of the ten channels.
Push the "LOCK" button to lock out channels you no longer want to listen to, or that you want to ignore temporarily.
Posted on Dec 09, 2009
Need a manual to program radio freq for a RCA four band veractor tuned scanner, this is not a gps but a radio scanner model # 16S400
Please excuse me if I've already answered your question -- it sounds familiar. The RCA 16S400 is a 70's-vintage crystal based scanner that covers the VHF-Low, VHF-High, and UHF bands using frequency-specific crystals. It is not programmable, but rather requires one crystal for each frequency to be scanned/tuned. It uses Regency-type crystals which can usually be found on eBay at reasonable prices.
Bill B.
Listening in since the 60's
Oct 13, 2010 | Radio Shack Pro-96 Scanner
How do delete a frequency code from my scanner i know how to program but dont know how to take a frequency off thanks
Just program 0.0 (zero point zero) into a channel to clear the existing frequency. Also, programming a new frequency into a channel will overwrite/delete the previously programmed freq.
Bill B
Aug 02, 2010 | Uniden BCT8 Base Scanner
I'm having problems programming radio frequencies on my scanner.
You didn't mention the make or model of your scanner, so I can't provide a response specific to your unit, but the trailing zero is meaningless, so there's no reason to enter it. Some bands on some scanners will only accept three decimal digits, but the scanner should round off your entry and still receive the intended frequency.
Bill B
May 02, 2010 | Radio Communications
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
Need schematic for Regency z30 police scanner
Make sure you lock the memory switrch in back to on this should slove your problem Good Luck
Sep 28, 2009 | Radio Communications
How do I program a Regency Z30 scanner?
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you want to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission to wait for the next response, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Jul 10, 2009 | Radio Communications
I dont no how to program my regency z30 scanner
1. Press "MANUAL"
3. Press "ENTER"
If you wish to add more frequencies at this time, got to step 2.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
Apr 07, 2009 | Office Equipment & Supplies
How to program an old regency 1060 scanner
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Oct 11, 2008 | Uniden BC72XLT Handheld Scanner
Uniden bearcat scanner
The scanner was probably turned off and it forgot what frequencies were programed into it. Older scanners have a problem with retaining their memory when they are shut off. Most of the older scanners have a memory back-up battery that helps the scanner retain its memory. Check and see if this battery is still good. As for your frequencies, you'll have to reprogram the scanner. To put it in technical terms, some older scanners have what is called RAM (Regency Alterable Memory) and ROM (Regency Organized Memory), when you turn off you scanner, this memory is erased, along with your programmed channels. Be sure not to turn off your scanner unless you're willing to reprogram the scanner.
Apr 30, 2008 | Uniden BC60XLT-1 Handheld Scanner
Programming
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
Radio Communications Logo
144 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
