Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Burning belts The Washing machine belt burned, I replaced it and two days later the new one burned, replaced that one and the same day it too burned. The drum seems to be sticking at the beginning of the spin cycle. It aggitates fine and doesn't stick every time. This is a GE water saver washer/dryer stack unit. Model number unknown.
  • 1 more comment
  • tony266 Jan 19, 2008
    I will try that this evening, Thank you. It would be nice if that is all that my problem is.
  • tony266 Jan 23, 2008
    I looked through the drum as well as I could and found nothing. The problem seems to be when the machine switches from aggitate to spin. If you let the machine run it's aggitate and drain and then stop it just as it goes into the spin, which the motor is turning but not the drum pully, if you grab the pully and turn it you hear an audible "bump" and then you can start the machine back up and it will run the rest of the spin cycle with no problem.
    Any ideas? I was wondering if maybe the clutch was sticking... just a though. Thanks , Tony
    I'll see this evening.
    President:
  • 1,314 Answers
Try taking a flashlight and looking very closely at the holes in the tub with a flashgoht to see if a foreign object such as a nail or screw has fallen through one of the holes in the tub and jamming it try to rotate the tub by hand and let me know
Posted on Jan 19, 2008
  • robert samples Jan 19, 2008
    ive seen it happen many times but if not just reply
  • robert samples Jan 23, 2008
    listen is the belt loose you can adjust it by looseing the motor and sliding it bacl
Smell of burning rubber and smoke from drawer
Sounds like your drive belt is loose or worn out. You will probably need a new belt. Is it possible something got inside the machine and jammed the belt?
Dec 12, 2014 | Hoover Washing Machines
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Serpentine belt snapped 2 days in a row, the belt was burning the other day but today it just snapped and my anti freeze started to come out
A burning belt usually indicates a seized idler pulley on those gm cars. You will have to find which pulley is seized and change, it before replacing the belt or the new belt will only burn and snap again.
Sep 23, 2010 | 2001 Oldsmobile Aurora
My neptune washer smells like rubber burning when i wash clothes
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer.
The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer. Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the 2 plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | Maytag Neptune MAH6500A Front Load Washer
Overloaded washer, smelled burning. Washer works
On this machine, you most likely just burned the drive belt. The old dependable care transmission design was pretty hard to kill, so just get yourself a new set of drive belts. Very easy to replace/install. You can just tip the machine back to access them. There is a lip on the bottom of the front panel that will hide the pump belt but enough room above it to unwind it off the pulleys. If you want, the front panel can be removed, early models used two phillips head screws to hold the front on or later versions used two clips on the bottom that you can release with a putty knife. Pull the bottom of the front panel forward to un-clip the top and away you go.
Jul 02, 2010 | Maytag Dependable Care LAT9206
Vacuum smells like rubber burning. Replaced belt. same result
My vacuum's belt fell off, So I fixed it. Two days later my vacuum wouldn't turn on, so I opened it up again and took out a dust ball in between the electrical wires. I turned it on and sparks and snapping sounds came form the motor. Also burning rubber smell, What wrong? Is my vacuum fixable?, or should I buy a new vacuum?
Jan 15, 2010 | Oreck XL2000 Bagged Upright Vacuum
Burning rubber
hi! we have read your problem at Fixya! since you have specified that it smells like burning rubber, the belt connecting the motor and the tub accelerator might have been wearing out.this is a problem which occurs when you overload the motor frequently.if you get the smell continuosly, open the cabinet and get the replaced.hope your problem is tackled.have a nice day
May 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Amana dlw330 washer belt burned & broke again after I replaced it
well if hte washer belt is "burning off"" that tells me the motor is trying to spin at full speed buthte transmision pulley is holding it back, can be a few issues, either the brake is notreleasing correctly or, the transmission is locking up .
Feb 26, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Fridgidaire Washer burning belt!! Help
http://www.applianceaid.com/frigwestwasher.html#burnt-belt
look on this site for more aid, it may not be your exact model but has advise on burning belts
Nov 10, 2008 | Frigidaire CWS3600AS Top Load Washer
Dryer not working
The smell was your belt burning into. (If it smelled like rubber) Take the bottom of your back panel off and you will see your belt just hanging in there. Cost $15 to replace and eazzzy to do.
Oct 27, 2008 | Frigidaire GLWS1339CS Top Load Washer
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
