Question about Install Essentials 489P Responder 2-way Remote 902
When I start my car using my 950 Python auto start remote, the car runs for only about a minute then turns off. How can I fix this?
    Problem Solver:
  • 6 Answers
Does your vehicle surge at all when its running becuase if the Python see's any fluctuation in RPM it will kick out.
Posted on Jul 16, 2010
Python remote start
I'm not positive, but I'd bet your remote has an issue with electronics, or it could be as easy as the battery in your remote
Thanks, Terry
Mar 14, 2014 | Vehicle Parts & Accessories
Python remote start lighting sequence
The automated lighting has ambient light sensors and an electronics package that can cause similar issues when they fail.
Mar 08, 2017 | DEI Python 1400XP Remote Start/Keyless...
Remote start/alarm works not working properly
First, find the fuse, and sensor to the devise. Pull the fuse and waite a few minutes then replace. Do the same with the sensor, this will clear the devise settings on the cars computer. Then start your car and let it run through the computer system check of all car devises, it will locate the Python devise and resetit. If you have trouble in this process, look your unit up on line and call the tech department and they will walk you through the process. Then go back to Jeffy Lube and have them comp you for their lack of knowing how to work "around" this devise.
Apr 29, 2017 | 533 2way Security Remote Start System
Set up the car remote
A 7701P is a remote transmitter. It is not an alarm. You must know the alarm's model because different models have various ways of programming transmitters. In other words, you do not program the 7701P. The frequency is already fixed. You must program your security system to teach it that transmitter's code. Look up the manual for your security system. Instructions will be there. This typically involves turning the ignition on/off a specific number of times and pressing a valet/programming button (or switch) a certain number of times and then pressing a button on the transmitter.
Jan 31, 2013 | 990 And 950 Responder SST Remote - 7701P
How to turn light on the python 990 remote?
If you just want the LCD backlit turned on, press and hold the program button on the back of the remote until the remote gives a long tone, that indicates that you've entered programming mode. Then within 5 seconds of entering programming mode press the the unlock button. The remote will beep once for backlight on and twice for backlight off. In the "on" setting your backlight will turn on each time a button on the remote is pressed. It will run down your battery faster though. It's the same for both the 990 and the 950 remotes.
Nov 16, 2010 | 990 And 950 Responder SST Remote - 7701P
How do i remote start my car with this python sst remote?
I believe you press the lock and unlock at the same time.
Jul 04, 2010 | 990 And 950 Responder SST Remote - 7701P
My python remote starter when starting in the morning only wil will runl. On my 2008 dicota truck will run less than a min. And shot itself off only in thr morn.
You need to reprogramme the tach input, the engine is running colder in a morning and will run higher for a few minutes, during the day the engine will be warm and idle quickly.
Nov 21, 2009 | DEI Python 1400XP Remote Start/Keyless...
When i bought the car it was disarmed maybe cause it was towed?
Do you have the alarm's remote fobs? If not do you know where the valet button lives? It's a little black button hid somewhere under the dash. Anyway put your key in ignition turn key to "run" position and within 5 seconds push the valet button and that should stop the alarm and allow you to start the vehicle. OK after you get the vehicle started turn it off and hit the valet button again. The blinking LED should be solid not blinking and that's telling you your in valet mode which means the alarm is off, the conviencince features like keyless entry and remote start will still work but the alarm is standing down.
Aug 11, 2009 | 990 And 950 Responder SST Remote - 7701P
Remote starter will not start vehicle
first thing i would try is locate the main box for auto start. usually it is under dash on the driver side when installed. then find the lage or hrness with the most wires going to it and unplug it/wait a few min. then plug it back in. sometimes the unit will go into a security mode. this will just reset it. if this doesn't work then let me know
Jan 06, 2009 | DEI Python 1400XP Remote Start/Keyless...
Install Essentials 489P  Responder 2-way Remote  902 Logo
446 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
