Question about Zanussi IZ161S Front Load Washer
The wash keeps stopping and E20 comes up in the window
Your washing machine has a code in it that will tell you the problem if you phone the company
Posted on Feb 19, 2010
SOURCE:
E20 error message
maybe you should just get a new washing machine
Dec 11, 2013 | Washing Machines
E20 aeg washing machine
Sounds like water leak under machine, Polystyrene Float switch activated keeping pump on thus avoiding flood.
Nov 26, 2013 | Washing Machines
E20 keeps coming up on my washing machine
E20 Error Code - means, not draining
It seems more as an issue of a clogged drain line, filter go to bad or malfunction pump.
Hope this helps.
Mar 31, 2011 | Washing Machines
I have a aeg 72360 update washing machine and it keeps stopping and coming up E20. It will not spin
make sure the drain pump is operating correctly or if so, check the motor brushes.
Aug 09, 2010 | AEG Lavamat 72640 Front Load Washer
E20 keeps coming up on washing machine and wont drain
E20 is a code for the consumer only. Electrolux would determine this to be E23 most commonly. This is because there is a blockage in the filter, drain hose or plumbing
Mar 31, 2010 | Zanussi IZ161W Front Load Washer
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
Mar 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
My aeg washer dryer comes up with e20 flashing i have checked the pipes, changed the pump cleaned the bottom filter, pump is now working but e20 fault still comes up half way through the wash cycle... how...
I had the same problem (E20) for a long time and tried everything in the manual before I called AEG to have someone stop by and fix it.
He took the whole top off as well as the back and pulled out all this fuzz that was stopped somewhere. He said it normally comes from using too much detergant and also from not letting the machine run empty every now and then....but it doesn't say to do this in the manual. And anyway, I can't imagine that using too much wash powder made 1/2 kg of fluff.
I still have a guarantee on the machine, but they say that because it is my fault that I got E20 I have to pay for the repairment myself.
I actually think that they build the machine purposly in this way to keep up the money flow. I have an attorney on the case now.
Dec 21, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi IZ161S Front Load Washer Logo
62 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
