Question about Acer Aspire 5500 5570-2609 Laptop
New laptop. mouse pad is not working - Acer Aspire 5500 5570-2609 Laptop
  • 51 Answers
Maybe the mouse pad was not connected inside since its new, find a technician who can connect it
Posted on Dec 09, 2009
Free laptop, broken mouse pad.
Keep using the wireless mouse as if the on board pad is broken, it could be an expensive job but try new drivers first.
Nov 12, 2015 | Computers & Internet
Mouse pad won't work
Reinstall the driver for the touch pad. If tha still doesn't work, I would suspect the touch pad itself and buy a new touch pad for your laptop, or an external usb/wireless mouse.
Dec 22, 2013 | Sylvania G-Netbook
How di make my mouse work
usb mouse or mouse bad ?
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
Examine your mouse pad.
Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether.
Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component.
Check to see if your mouse pad has been turned off.
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work,
Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area.
Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input.
It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad).
Then, click on download.
Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again.
hope this helps
Sep 09, 2012 | Compaq Presario CQ57-339WM
Mouse pad wont work
if this computer is new, return it and buy a new one. if you can't return it anymore, buy a mouse and plug it in. it's your best hope.
Jul 26, 2010 | Acer Aspire 3000 Notebook
My laptops mouse is not working
IF you are referring to the external mouse attched to your laptop
then please check the same mouse with some other systm to verify if
the issue is with the mouse or with the laptop.
if the mouse is working fine with other system, then you need to
contact the service provider of your laptop.
Otherwise you have to buy a new mouse.
If you are referring to the touch pad of your laptop not functioning
properly, then please check the touch pad settings through control panel.
otherwise please shut down the laptop.
Take out the baterry out & wait for atleast 1-2 minutes.
Reinsert the Battery in the laptop & reboot the laptop.
Check if the mouse is working fine or not.
If the problem with the laptop still persist, please contact your
laptop service provider for further support.
Hope this will help you in resolving the issue.
Cheers!!!
Vivek
Dec 26, 2009 | Computers & Internet
Mouse pad isnt working??? I just got my ASUS laptop today NEW. when I boot it up mouse touch pad won't move cursor to log in ect.
r u in DOS mode ? mouse wont work in DOS mode..
if u got the Win Logon screen and mouse does nto work....
Shutdown the machine....
and send it back for a full refund or replacemnet....
u say it's new....so dont fiddle with it...
if u have an external USB/PS2 mouse u can connect it to the USB port or the PS2 keyboard/mouse port and check if the machine is working....
i suggest u send it back or take it to the shop where u got it...
Dec 25, 2009 | Computers & Internet
Lenovo n500 laptop ... mouse pad not working
The mouse pad maybe faulty or the ribbon cable from the mouse pad to the motherboard may not be properly connected. Reseat this cable.
You can connect an USB optical mouse to the laptop. I prefer you use a USB mouse all the time over the mouse pad.
Sep 29, 2009 | Lenovo 3000 N500 Notebook
Mouse pad not working
A mouse pad is a thing you put your mouse on....
now what you are talking about is your touchpad.
Check these first:
  • some laptops have a switch that turns off the touch pad (usually a button right on the topside of the touchpad)
  • did you reboot completely? full shutdown, then power on?
  • goto the device manager (with a usb mouse of course) and find the touchpad... delete the device... then reboot again it should try and find the touchpad and ask for the driver, point it to the directory that you have the driver located.
good luck!
Apr 21, 2009 | Computers & Internet
HP Pavilion Entertainment PC - scrollbar on mouse pad not working
hi there.
maybe your mouse is not comaptibel with the system of your laptop or you need the disk driver to install the mouse to work properly?
or your mouse is already damage and need to replace try to change it with a new one.
Feb 14, 2009 | HP Pavilion dv6000z Notebook
Keyboard and mouse inoperative
its the battery. disconnect the battery, plusg it up and start you computer. the mouse and keyboard should work fine.
Nov 14, 2007 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
