Question about Sony DCR-HC26 Mini DV Digital Camcorder
My sony handycam dcr-hc26 door won't close. error C:32:11
  • 4 more comments
  • sbennett1123 Dec 09, 2009
    I've already done that & it still will not close.
    Yes, I would need the tape mechanism part & a referral for repair.
    I'm trying to remove all the screws to how to replace the part. Does the tape run from the back to the front?
    If I purchase, is that I'll receive because Nextronics does not supply a picture of the part?
  • Eddie Dalton
    Eddie Dalton Apr 28, 2012
    solved my problem, thanks a million!
  • jrhottle Oct 20, 2012
    Yes I need tape mechanism part number info. Thank You!
  • 10,594 Answers
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Let me know if you need tape mechanism part number info.
Thanks.
Posted on Dec 09, 2009
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Dec 09, 2009
    That means tape mechanism has problem and might be cam gear is broken. Need to replace complete tape mechanism under following part number..
    A1080997A MD (N100) SUB ASSY A
    Available in Nextronics for $63
    Below is an image of required tape mechanism.
    Thanks.
    Check below image that shows how to apart camcorder.
    I would recommend to download service manual of DCR-HC26 from HERE for small fee, it has all technical info, help to apart, part list etc.
    First LCD section will be removed, then front cabinet, then battery compartment, then camera lens assembly, then main circuit board and then you can take out tape mechanism.
    Be Careful handling flexible wires/ orange strips that are easily damaged like paper.
    Thanks.
    Yes, you will get same part as shown in above picture.
    All you need to transfer/ put video head drum assembly from old mechanism to new one. 3 screws to remove to take out old drum assembly.
    What was wrong in solution that it got rejected by you?
    Problem Solver:
  • 6 Answers
The tape can be moved without battery. apply 5v DC to the tape drive motor (a small motor at the bottom of camcorder) you'll see two small semi-hemispheres on top of motor. you'll need to figure out which one is positive by trial and error. nothing bad will happen as long as the voltage is not more than 5v.
Posted on Jan 31, 2010
3 Suggested Answers
SOURCE: Sony Handycam DCR-HC26
don't expect any help from sony, they are too lazy to take the time, i'll never buy sony again
Posted on Nov 08, 2008
SOURCE: i have a sony handycam dcr-hc26 that wont close
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Posted on Nov 24, 2009
Where is the A/V out on sony handycam DCR-HC26?
Is this information not contained in the camera manual ? If you have no manual, you can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Oct 23, 2016 | Sony DCR-HC26 Mini DV Digital Camcorder
Repair handycam touchscreen
It should be the first screen you see when you turn it on, if it has not been set. This is an old camera, so the internal rechargeable battery that saves this info may be dead.
here is the manual in pdf if you don't already have it.
https://docs.sony.com/release/DCR-HC26_Instruction_Manual%5B1%5D.pdf
Dec 27, 2013 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
My driver door won't close on my Sony Handycam 20x
Try this, it worked for my Sony handycam:
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take?»¿ OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
Dec 25, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a Sony handycam DRC-HC26. After placing the DV tape the tape refuse to load into the tape compartment and as such the tape door cannot be closed. Please advise.
The mechanical of tape loading compartment is misaligned and it needs readjustment which is a bit technical issue. Please contact any expert for mechanical adjustment of tape loading path assembly.
This will solve your problem.
Thanks.
Nov 24, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
LCD screen not working on my Sony handycam dcr hc26
Usually there is flexible wire between lcd board and main board of camcorder that got broken and resulted lcd does not work.
You need to replace that flexible wire by qualified camera tech.
Thanks.
Sep 20, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Aug 20, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
XP does'nt recognise Handycam
you will have to use the supplied software or just about any other video editing software to download the video to your pc. here is a link to a retail outlet for sony software.
http://www.picture-package.com/product_info.php?products_id=127
Mar 23, 2008 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony DCR-HC26 Mini DV Digital Camcorder Logo
6,203 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
