Question about Sony VAIO® VGC-LS37E PC Desktop
The computer seems to get no power.
I put the computer in sleep mode. When I returned, the geen light at the top left was off and it has not come back on. I checked the power plug with a voltage meter and it's ok. Any idea??
    Problem Solver:
  • 11 Answers
Unplug the power cord from the power supply on the computer, wait 2 min. plug back in and hit the power button...if the computer does not turn on, then the power supply has a short in it or a bad fuse.....you would have to either replace the power supply or the fuse inside the power supply...i would just get a new power supply....
Posted on Dec 09, 2009
How to open hp laptop in sleep mode
This is a common problem on HP computers but also has many causes. If your laptop is not coming back on after being put into sleep mode, it could be a software issue among a few other things. If your computer has a hibernation mode I would suggest using it to get around the sleep mode issue. This mode will save everything the way it is and shut down completely. When you restart the computer it will open up just as you left it. Just like sleep mode except with a restart. This does not solve the sleep mode problem but easily provides a power saving alternative to it.
Jun 25, 2013 | HEWLETT-PACKARD HP Mini 5101 Netbook
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
I was using laptop, closed the top to put to sleep, on opening up back the laptop i disconnected power supoly for is was plugged in and then my computer shut off, it seems the battery is not responding...
sleep mode if all the hardware is still on, not what to perpergian sebantar pake sleep mode, for a long time you turn off / Shutdown. You can also laptops batterynya already can not store electricity. you try to charge back or replace a new Battery
Jul 27, 2011 | Acer Computers & Internet
Vista computer HP in sleep mode. How to get it
Typically you can just press the power button once, and the computer should come out of sleep mode.
Be sure to power off your comptuer regularly to reduce risk of freezing when computer enters sleep mode
To chance Sleep Mode Settings follow instructions below:
First click on the start icon at the bottom left hand corner of your screen and type into the start search box :power options , now click on "power options" it will be at the top under programs, next, under perfered plans section you need to click on " change plan settings" that is under the plan that has already been selected, this plan has a blue dot on it , come down to and click on " change advanced power settings" , now you need to scroll down to "multimedia settings " in the window that has just been displayed, click on it's box to open it up , then do the same to " when sharing media "' now click on the text to the right of "setting" it is light blue ,this will high light it and you now click on the little arrow . select " allow the computer to sleep ", lastly click on ok!
Jan 06, 2010 | HP Pavilion dv9000z Notebook
What is 1/4 moon symbol on top left of my compaq keyboard ? when i press it seems to put my computer into sleep mode . how do I get my computer started again ?
You are correct. The moon is sleep mode. Closing and opening the lid will often take it out of sleep mode. You might have to "unlock" the keyboard as well by entering a password (just hit return if you haven't entered a password.)
Under power options, you can select what the computer does in sleep mode.
Jun 20, 2009 | Compaq Keyboard
Yesterday, I left my computer to talk with a
I would need some more information to completely help you. When you say you walk away and the pc shuts down and starts back up, does it close down (reboot) or does it go into screen saver / sleep mode? What button did you push for the power button light to blink? Have you put the PC into sleep / hibernation mode by pressing the power button once.
Apr 07, 2009 | Gateway MX3225 Notebook
Sony VAIO® VGC-LS37E PC Desktop Logo
95 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
