Question about Microwave Ovens
Electric 30 gallon water heater has a new element and 220V at the element contacts but no hot water? Bradford and white model m230r6ss-incy
  • 2 more comments
  • dsbinnion Dec 10, 2009
    Didn't work, but Got 220 again at the element contacts, any other suggestions?
    I have installed a new element and a new thermostat - they both test good - there are 220 volts present at the element. Still no hot water.
    Thanks Waynard, I figured it out when i tested across the element contacts and only got 115V.
    The problem is at the service pole not the water heater.
    Dana
    Thanks again!
    President:
  • 1,901 Answers
Hello, First, if your thermostat has an ECO (High Limit) reset button, turn the power off at the breaker. Press the reset button. Apply power. Here is the procedure to further check the heater: 1. This procedure assumes line voltage, ECO and elements are in working order. 2. Turn power ?ON? to water heater. 3. Set multi-meter to ?Volts AC?. 4. Check across terminals L4 and T2 of thermostat. A) Rated voltage NOT present, Recheck ECO. If ECO is okay, replace thermostat. B) Rated voltage IS present, proceed to next step. 5. Check across element terminals A) Rated voltage NOT present, check wire connections from thermostat to element. B) Rated voltage IS present, Repeat element testing. To test element: Step 1. TURN OFF POWER TO WATER HEATER. Step 2. Remove access cover(s) from front of water heater. Remove insulation and plastic cover from thermostat. Step 3. Disconnect wires from heating element. Step 4. Set multi-meter to ?ohms? setting. Step 5. Touch probes of multi-meter to screw terminals of heating element. Step 6. Reading should be 12.8 ohms (±6%) for a 240 volt, 4500 watt element. If infinity, element is open. Here is the service manual for Bradford White heaters. This covers several models. http://www.bradfordwhite.com/images/shared/pdfs/manuals/238-47104-00A.pdf
Posted on Dec 10, 2009
  • 2 more comments
  • Wayne Mineard
    Wayne Mineard Dec 10, 2009
    I apologize for the format of my post. This is a system bug that happens occasionally. I believe it is still understandable.
    Thanks for using Fixya.
    Wayne
  • Wayne Mineard
    OK, by the model # this IS a single element tank, correct?
    Just to verify:
    Incoming black to L1
    Incoming red to L2
    Black to element to T2
    Red to element to L4
    Also, what are the EXACT readings from:
    Grd to element red side
    Grd to element black side
    One probe on red side and one on black side of element
    And....did you fill the tank before applying power?
  • Wayne Mineard
    Also, if a single element, what is the rating on the side?
    I would also ask that you verify the resistance of the element. Power off and remove wires from the element and measure from one contact to the other.
  • Wayne Mineard
    I asked about filling the tank before power up because if you power w/o water the element will burn out due to "dry firing".
    I asked about the rating because of it is only a 120V rated element, it will also burn out as soon as power is applied. (Water or no water.)
    Only way to verify the element is good is to ohm it out with the wires disconnected. If it reads infinity it is bad. It should read about 10 to 15 ohms.
    Wayne
  • Microwave Ovens Master
  • 19,396 Answers
Hi.
Test the thermostat.
The thermostat is tested cutting its contacts and reading Ohms with a multimeter set at Rx1.
A good thermostat will read low or no impedance at room temperature, and will cutoff at limit temperature.
An alternative way to test a thermostat is bypassing it.
Test and eventually replace the thermostat. If thermostat is good check wiring and electronic control.
All test and repair must be done by a trained technician.
Regards.
Posted on Dec 09, 2009
  • Ginko
    Ginko Dec 10, 2009
    If an element get 220V, and the element is good, then the element will warm up.
    If the element does not warm up, then either the element is not getting volts during cycle, or the element circuit is open.
    To check if the element is good read Ohms (impedance), not volts. If impedance is infinite (same as in the air-circuit open) then the new element is still not working. Testing Ohms must be done with one of the two elements contacts not connected.
    If the element is heating up, and water is not being heated, and element and thermostat test good, then it can be a water level switch disconnecting element because it wrongly senses that there is no water, or a faulty electronic control board.
    Water level switches are of two kinds, pressure and membrane switches, and float switches. Both can be tested reading ohm on switch and bypassing them.
    Apart this there is no much to test in a boiler that has a good element and thermostat.
SOURCE:
I can;t find manual and I want to clean my keurig coffee maker
You may be able to find the User Guide for your Keurig machine here:
http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help
Your brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar. Full de-scaling insturctions can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Mar 26, 2011 | Microwave Ovens
Inserted K cup and closed machine. Says Brewing but coffee machine only dispenses a few tablespoons of water...tried turning machine off and off, but same amount of water is dispensed each time, no matter...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 01, 2011 | Microwave Ovens
Does the dishwasher model GDB742RJS0 have a heating element or does it require a cold and hot water hook up thanks
Yes, your dishwasher has a heating element. You only need a hot water hook up. attached is a picture of some of the parts in your dishwasher. The heating element is #1. It is located at the bottom.
Hope this clear things up.
Please vote and add any comments you wish.
Mr Tin Man
Dec 21, 2010 | Westinghouse Microwave Ovens
I have a water cooler and the hot water does not get hot anymore the cold is fine
It probably requires a new heating element. Contact your supplier to get a price.
Nov 07, 2010 | Microwave Ovens
Hello I just bought a Kenmore Electric Range and I am now installing it in my kitchen. I am attempting to connect the power to the range. I have a large romex looking wire coming from the house wall....
Are you trying to connect your range to a 3-wire source, using a 4-wire cord? I'm a little confused on your symptoms. Normally you have a 2 HOT leads and a NEUTRAL/GROUND (3-wire) in older homes. In newer homes you have 2 HOT leads, a separate NEUTRAL and a separate GROUND (4-wire).
The following link explains the difference between the two configurations and how they should be correctly wired:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
New construction homes built after the year 2000 REQUIRE the use of a 4-wire plug and are usually readily wired at the receptacle to accommodate. If your existing receptacle already has a 3-wire configuration you do not need to re-wire it, however. The easiest solution would be to purchase a 3-wire power cord that matches the receptacle you have.
Read through the link provided and post back and let me know if you have any questions. I hope this helps you solve your problem.
May 22, 2010 | Microwave Ovens
My 15 year-old RHEEM Warrior Model 71-40S forty gallon electric water heater is leaking, and the element also needs replaced. I am thinking it is likely time to get a new, energy-efficient model versus...
Rheem makes great products. Lowe's sells whirlpool brand and they are not all that bad for the money. I would buy something better than the budget 7 year warranty model though. My preferred choice is AO Smith. I would definitely replace your water heater if it is 15 years old- most don't go much longer than that, although mine is 27 years old and going strong! Please remember to make sure and extend your pressure relief valve down to within 6 inches of the floor when replacing the water heater as Code requires. A water heater blanket will also earn its keep in a short amount of time.
Jan 02, 2010 | Microwave Ovens
Just purchased a new Maytag smoothtop cooktop from Home Depot. Installed the the wiring according to the manual. However when turning the knob to the on position, the indicator light flashed briefly and...
Electric ranges are normally 220V and that goes with what you have. The maytag guy has nothing to do, so give him a call. It may be a problem you can't ouch anyway since it is new and under warranty.If it is wired correctly, which it appears to be, a service call will be covered. Good luck.
Oct 29, 2009 | Microwave Ovens
The microwave runs for 3 to 4 seconds and then shuts down. I have to re enter the time, date and press start. It runs for 3 to 4 seconds and I repeat. Other times, it works just fine. But needs restarts...
If it is resetting, there is a chance that the problem is not with the microwave but the AC supply. These units draw a bunch of current and if there are any sloppy connections or a bad outlet (if plugged in), the connection can fail long enough to drop the AC input far enough to turn the unit off.
A circuit breaker (in your main power panel) can cause this too; I've replaced bad breakers in our new home already that were doing the same kind of thing your microwave is doing.
A bad AC connection can also be a fire hazard since they are also capable of getting hot enough to start a fire.
If the source of AC is via an outlet, check around it to ensure that there is no discoloration of the outlet's exposed plastic. If ther is, that is a sure sign of poor contact between the unit's plug and the outlet's contacts.
There is a remote chance that the magnetron is developing an internal problem; these are vacuum tubes of a sort and have a fast-heat heater element in a cathode that spits out electrons. One type of failure is when the cathode and heater come in contact because of the expansion of the heater element (happens each time it is turned on) then a very high voltage is brought into contact with the heater and causes a momentary short and high currents.
Aug 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The electric dryer is about 10 years old. Came with house. It does not dry a load such as towels in less than 1.5 hrs. Typical with our previous GE was 30-40 minutes. Would a heating element be gone, dirt...
if it still gets hot its not the element your dryer vent could be stopped up not allowing air flow if its not getting hot the element is easy to change pull the back off after unplugging the dryer the wires easily unplug and take off screws you can get the part number from your local dealer with the model and serial numbers
Apr 07, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
