On my 2025 I am getting a lot of extra toner on the page just after the developer what most likely cause? it was on it's side during a local relocation and has been cleaned up but can see where the page has a lot of extra toner coming out of the developer station.
  • Office Equip... Expert
  • 267 Answers
This means that there is a lot of toner concentration on the developer which probably is giving very bold copies. Try to run command 25 sub-code 01 to minimize this toner and make a copy after this. If the copy is clean, run command 25 sub-code 02 to store in memory. To run commands, press ' C, interrupt, 0, interrupt keys' , the display will go off then key in 25 press copy key then sub-code then copy key and let it run till it stops. Press CA key.
Posted on Dec 09, 2009
    New Friend:
  • 99 Answers
Adjust developer brush two side screw down or up position.
SOURCE:
Hp laserjet 3200
take printer outside of building
pull out toner cartridge and drum carerfully
Spray inside of printer to get rid of split extra toner with a can of compressed air - usually available from an electronic supply shops
Check the drum has no tone split on it .
Put drum and toner cartridge back into the printer
Jan 26, 2018 | HP LaserJet Office Equipment & Supplies
Over toning
do you have extra toner dropping on to the paper path after you clean it? That is what is sounds like. You are either having waste toner fall onto the paper path from the drum blade or cleaning reservoir. Or your developer is dropping toner as it shower the drum. If you are not having imaging issues, besides the toner on back; you might want to check the separation or transfer coronas and their voltages (ie...make sure all your grounds are good and clean) or it might be a voltage biasing problem.
Because somehow you are getting toner into the paper path after the copy. UNLESS....you did not clean the paper path good enough and you are just getting leftover run-off until the documents can clear it all.
But, always try the simplest things first!!
Good Luck!!
Jun 07, 2012 | Toshiba estudio 255 Copier
What means "943.02 Service Black TMC Sensor"?
A 94x.xx TMC Error indicates that the printer has failed to detect the Toner Metering Cam for a specific cartridge. This error typically occurs when the cartridge or developer are misaligned or incorrectly seated
Please click on the link http://bit.ly/ozldpC to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Feb 20, 2011 | Lexmark X543dn Laser Color All-In-One...
Cleaned the drum by running the slider on Brother IntelliFax 2800
Clean the corona wire, reclean the drum, check the toner cartridge. The cartridge may not be positioned properly, causing extra toner to be displaced.
Jun 19, 2009 | Brother IntelliFAX 2800 Laser Fax
HI, I have a clp-300 and it is printing black only on the right side, but the left is completely washed out. it works fine when I use a color other than black
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I have a document to show you if you are handy.
Jan 18, 2009 | Samsung CLP 300 Laser Printer
Color problem!
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. It sounds like the magenta blade needs to be cleaned. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
Jan 13, 2009 | Samsung CLP 300 Laser Printer
Pring quality on Samsung CLP-300 colour laser
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I don't have 20000 images it is about 7000 and I have a document to show you if you are handy.
Dec 10, 2008 | Samsung CLP 300 Laser Printer
Sharp 2025
You have to take out the toner/developer box. Unscrew the top portion(usually blue screws), then separate the two. Dump out the old developer and vacuum out the remainder. OPen the DV bag and slowly poor the dv into the unit evenly. then rotate the DV cylinder with e screw driver at the rear to blend it onto the dv roller. close the unit and reinsert to copier. There is service mode to run the toner into the new developer. You can contact me to find this out.
Jun 12, 2008 | Sharp SF 2020 Copier
Adding developer to sharp sf-2025
Hi, it means the developer requires changing. it has a life of 30k (i think). I would suggest that if your quality is not effected, then keep using the machine, or spend the money on an engineer to come out and replace it.
Andy
Feb 28, 2008 | Sharp SF 2020 Copier
41 people viewed this question
k24674
Marvin
Marvin
