Question about Mitutoyo 0-.5" FLAT.00005" MITUTOYO DIGMATC INDCATRS
Gage will not hold zero setting. - Mitutoyo 0-.5" FLAT.00005" MITUTOYO DIGMATC INDCATRS
    Sniper:
  • 61 Answers
This is not uncommon for a gage like this with such a close tolerance. A small change in temperature can cause this gage to jump off zero due to the thermo-expansion of the materials in the gage itself. If you were to set this gage on a part, zero it out, and just breath on it, the temperature change created by the heat in your breath will cause it to change. The gage is not faulty (unless it is reading way out of range), it instead is probably giving you a very exact reading.
Posted on Dec 10, 2009
SOURCE:
2004 Yukon XL 1500, with the car off the radio circuit draws alot of current and drains my new battery in 2-3 days. Also maybe seprate issue my oil presure gage does not reset to zero.
With the problem with the battery draining, Get the chargeing system check out, End tell them all so to check for a short, As for the problem with the oil gauge change the oil pressure sending unit,
Nov 26, 2012 | GMC Yukon Cars & Trucks
How do I set a imperial hvac guage
Are you trying to zero the gage? They have 3 types of calibration setups, so it will depend on the one you have. Be sure there is no pressure in the line, purge any lines or open the hand valves. Remove the plastic cover (should screw off by hand). Now some have a very small screw built in to the stop post, this post is a rest for the needle. if it has a slot turn this screw to set the needle at zero. Next is a slot on the center of the needle hand itself, look close and you will see a small center pin and a slot on ether side of that center. Use a small screw driver hold the needle hand and carefully turn the center one way or the other to re-zero the needle (may take a few trys). Next is a calibration screw built into the face of the gage (this is the easiest to do) turn it to zero your gage. Hope this Helps Fixya up.
Apr 25, 2011 | Heating & Cooling
Fuel gage goes to zero, twenty miles after filling.quickly after filling tank
Sound like you are in need of a new fuel level sensor. You have a burn on the wire wrap. problem is not sure if yours is available without purchasing a complete fuel pump
May 05, 2010 | 2000 Isuzu Rodeo
My accu-gage tire gage does not hold tire pressure reading. the dial drops slowly down to zero.
If there is a button you push to release the pressure (resetting the gage to zero), this is a valve which probably has a little piece of dirt impeding the seal of that valve. The dirt would have been carried there by the air and condensation. But don't take it apart to clean it. This is a typical problem with these kinds of gages. When you have plenty of air available (a compressor nearby) hold the gage on the valve stem, while you repeatedly push the release button. That should clear the dirt, but you may need to add more air to the tire.
Jan 17, 2010 | Accu Gage Tire Pressure Guage 60 Psi Range...
The oil presure gage goes up and down from zero to
All you have to do is replace your oil pressure sending unit.It`s in the rear of the motor by the left head.This is the drivers side.You need a special socket to remove the sending unit.Good luck.
Dec 05, 2009 | 2003 Chevrolet Silverado 1500
Truck runs great but the oil pressure gage goes zeros out
Did you find the sending unit and was that the problem?
Oct 05, 2009 | 1999 Chevrolet Silverado 1500
Fuel gage goes to zero and then to full while driving
Sounds like the sending unit is bad, which is in the gas tank.
Mar 15, 2009 | 2006 GMC Envoy
Mitutoyo 0-.5" FLAT.00005" MITUTOYO DIGMATC INDCATRS Logo
173 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
mikenearman
Vuk B
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
